I was undecided as to wether to fit the doors before or after painting the interior, as can be seen from the pic I eventually went for the before.
As mentioned in the previous post the Germans fitted a radio into the car, more than likely it was a FuG Sprech device as fitted into SdKfz 251's and many other AFV's, perusing my spare's bins I came across the radio from the old Tamiya 251/9 that I built when it first came out but had since been consigned to be used as parts. This fortunately fitted into the space between the wheel arch storage box and the deviding wall to the front compartment, so after a bit of work it was fixed in place and wired up as seen here.
One of the last assembly tasks was the mg mounts that fit onto the skate rail, as provided in the kit they are rather chunky and in dire need of finesse, fortunately Eduard provide some much needed detail for them so once built they were hacked about, cleaned up and finally received the etch details. The next pic shows the difference between the base kit parts and the updated one, apologies for the slight blurryness of this shot.
And next two much nicer looking mounts after getting sorted out.
It was at this point I decided that it would be fair to assume that perhaps a German fire extiguisher could have been added by its new owners so thats what I did, again using one supplied in the Tamiya Panzer IV set.
The final piece of assembly concerns the windcreen and its armoured screen, again the Eduard set provides a piece ot thin acetate to replace the very thick "glass" supplied in the kit, it also has a part that represents the inside framing, once the ejector marks were filled these were fitted onto the front frame with CA, I then turned to the armoured screen and once again dealt with its ejector marks before fixing the three uprights that hold it in the open position.
Finally I peeled off the masks from the backing and applied them to both sides of the "glass" to protect it from the up coming paintjob.
These were then fitted in place to (just about) complete assembly, the one final thing I added was a triangle of plastic sheet between the battery box and the wheel arch on the right side as again the pics show this to have been an actual modification, this nect pic shows both this and the windscreen/ armour in place.
