The wooden crate is the standard two round packing for 105mm shells. Inside the crate are two black fiber tubes which hold the rounds.
At 1/72 they will be tiny.
Glad to have been of help. Anything else just pull my lanyard!!
I've found a site that had quite a bit of information and pictures of 105 ammo that was primarily about post WW II rounds and packaging. They mentioned about two round boxes and black cardboard tubes. I've got the tube dimensions of 5" x 32" so if the box holds two tubes I'm guessing a box dimensions of 36"L X 16-18"W X 8-10"H? I'll try to find that site again and see if they have the actual numbers. Even at my guess dimensions the size is positively huge compared to some of the parts I had to deal with.
I used Prime Portal quite a bit during my build as the instructions are quite ambiguous in places.
Keith reshaped further electrons to comment:
Looking good Jan. Can't wait to see them painted.
I also can't believe you're gonna do a vignette and add tiny ammo crates?! Actually after seeing that microscopic piece in the alligator clip I can believe that.
My hat's off!
Thanks for the comments. I should also thank again all the people here that have provided information that has proved quite valuable in this build. As I mention above, the ammo crates are rather "huge" when compared to some of the parts that I've had to deal with. The clip in the picture you mention is holding the elevation and traverse hand wheels and is actually three parts. About the same size is the sight and even smaller is an adjustment knob on the towing end if the trail.
I've begun the painting and it (and the size of the kit) are presenting their own issues. I'm having to use a very, very thin brush with diluted paint to do the base NATO green. The problem is that there are so many miniscule crevices (especially in and around the gun cradle) that the paint from the airbrush just isn't or can't reach. I'm also reviewing all the images of the gun I have to see if there isn't a detail or two that I might easily add.
Now to talk to an ophthalmologist about correcting these crossed eyes!
Jan
