Canadian Leopard 2A6M help
Illinois, United States
KitMaker: 1,135 posts
Armorama: 1,030 posts
Posted: Sunday, January 31, 2010 - 08:58 AM UTC
Just curious, but is this build for the True North Strong and Free Campaign?
zaltar
You guessed correct
. Seems like these campaigns influence what I build next, but I am open to everything modern so the inspiration keeps pouring in.
Currently taking back the fight to beat modeling ADD
Posted: Sunday, January 31, 2010 - 08:59 AM UTC
Thanks Chris! I will definitely be using that to update it to 3rd generation side skirts.
Also:
Does anyone know where I can find the ARMO Barrel? And the Storm Miniatures is on the way! Included are the Echelon Decals and Barracuda Camo Netting
KitMaker: 1,036 posts
Armorama: 1,033 posts
Posted: Sunday, January 31, 2010 - 09:50 AM UTC
Armo 35793 Leopard 2A6 (Tamiya 35271) ... this is the one you could use.
Try this:
http://www.jadar.com.pl/armo/armo72barrels-a.htmCheers
Christopher
" He who seeks to defend everything, defends nothing " Frederick the Great
Posted: Sunday, January 31, 2010 - 10:12 AM UTC
Not available
KitMaker: 2,672 posts
Armorama: 2,475 posts
Posted: Sunday, January 31, 2010 - 10:22 AM UTC
Unless your absolutely hard set to get an aftermarket barrel, the kit one will build up very nicely.
Are you planning on the Barracuda Cam?
cheers
One of the serious problems in planning against Canadian doctrine is that the Canadians do not read their manuals, nor do they feel any obligations to follow their doctrine.
---From a Russian document
Newfoundland, Canada
KitMaker: 473 posts
Armorama: 467 posts
Posted: Sunday, January 31, 2010 - 10:52 AM UTC
I agree with Rick the Tamiya barrel is great. Sean save your cash for something else. If you want to go all out on AM parts get the tow cables from eureka, you can get those at the Barrel store. The tow shackles from Perfect Scale add nice detail to the model. Also the MG from Perfect Scale is better then the stock Tamiya gun. There was some Can. Leos with the FN style gun mounted, I think its called the C6, you can get a good resin version of that from Legends,its on my 2A4NO. You can get the Perfect Scale kits from Track Jam.
KitMaker: 4,085 posts
Armorama: 3,917 posts
Posted: Sunday, January 31, 2010 - 11:00 AM UTC
Do you have a close up of the bolt?
Of course I do....courtesy of Combat Camera....the high res image shows all the bolt detail.
http://www.combatcamera.forces.gc.ca/netpub/server.np?find&catalog=photos&template=detail_eng.np&field=itemid&op=matches&value=8004&site=combatcamera Drilling the recessed bolts out is not required. As you can clearly see in the image there is a metal washer and then the bolt. You could simply punch a thin disk as the washer and then punch a bolt head....glew them on over the recessed bolts and you are done.
Another way would be to fill the recessed holes with putty, sand them smooth and then add the washer and bolt detail. If you are using the Tichy bolts....just cut off the stems and attach them.
I think drilling the holes out has too much potential for damaging the surrounding plastic...as it appears to have happened slightly with Chris' attempt on the 3rd gen side skirts.
"We're not the public service of Canada, we're not just another department. We are the Canadian Forces, and our job is to be able to kill people."
July 2005- General R.J. Hillier (Retired), Former Chief of the Defence Staff
KitMaker: 473 posts
Armorama: 467 posts
Posted: Sunday, January 31, 2010 - 12:04 PM UTC
Jason give it a try its fast and very clean. the damage you are talking about could have been prevented by using the right size drill bit. The Tichy bolt heads do have a washer.
By keeping the stems attached the bolts are easier to handle. There are 100 bolts to deal with.
Posted: Sunday, January 31, 2010 - 06:12 PM UTC
Sauceman,
I was contemplating doing it however I'm not sure if thats what I wanna do. I really love the time and effort it takes to finish a model in the paint and weathering process but I don't think I can cover all that up. I got the netting just in case though. I'm sure I will use it at some point.
Posted: Monday, February 01, 2010 - 01:49 AM UTC
Sauceman,
There lies the dilema, spend the time painting and weathering, or installing the camo and cover everything up LOL.
When I do the Barracuda cam it will be with a HobbyBoss kit, where the soft detail does not matter.
cheers
Posted: Monday, February 01, 2010 - 09:31 AM UTC
Some updates:
I got ahold of the ARMO Barrel but I got it for cheap, I got it for 10USD and tow cables that Chris J mentioned for $4 USD.
I wanted to ask everyone:
What PE set would you use? Voyager Leopard 2A5 or Eduard Leopard 2A6 Detail Set?
KitMaker: 473 posts
Armorama: 467 posts
Posted: Monday, February 01, 2010 - 09:50 AM UTC
Sean where did you get the cable for 4 buck? Thats a good deal. The PE you want is the big Ed set that has the slat with 36 028 detail set. This set is the best one. Don't forget the shakles from PSM.
Posted: Monday, February 01, 2010 - 10:01 AM UTC
I looked at trackjam's site and they don't have them listed. Any suggestions?
KitMaker: 473 posts
Armorama: 467 posts
Posted: Monday, February 01, 2010 - 10:37 AM UTC
Direct from Perfect Scale, you can get the MG at the same time. About those Eureka cables if you don't mind telling me? I need 5 sets. $4 dollars is a lot cheaper then $10, which is what I paid for them the last time I ordered them.
Posted: Monday, February 01, 2010 - 10:47 AM UTC
Sorry Chris, they are actually Karaya Metal but I still got them for cheap. I thought these were the ones you were talking about.
I called Roll Models today and they were extra giving today
, but I've dealt with them alot. Just call and make sure they have some in stock.
Their direct number: (763) 545-0399
and the stock number: KAR35005
Praha, Czech Republic
KitMaker: 2,450 posts
Armorama: 2,409 posts
Posted: Monday, February 01, 2010 - 11:40 AM UTC
Chris
Please where is better PS MG. I look on photo and I think that this is Tamiya. Any PE details.
Let me know. Thanks.
Miloslav
Hope you like it and "watch those negative waves"
Posted: Monday, February 01, 2010 - 11:43 AM UTC
Sean I have in stock all Eduards set for Leopard. I have also nice GResin gun Barrel for my CDN Leopard 2A6M w/Slat armor.
This I plan place to produce next month.
Miloslav
Posted: Monday, February 01, 2010 - 12:01 PM UTC
Miloslav
Look for my order in an hour or so
KitMaker: 473 posts
Armorama: 467 posts
Posted: Monday, February 01, 2010 - 12:46 PM UTC
Chris
Miloslav
Milo I'm talking about perfect Scale Malibu's MG, its well detailed and the scale is better, there's no PE with it. Now that we're on the subject how about a FN gun and mount for the Dutch, Norwegian and Canadian Leopards.
Sean thanks for the tip. You're right about them being Karaya. I ordered Eureka and the Karaya came. They must have changed names or something like that.
Posted: Monday, February 01, 2010 - 03:55 PM UTC
What PE set would you use? Voyager Leopard 2A5 or Eduard Leopard 2A6 Detail Set?[/b]
The Voyager set for the 2A6 is excellent...it even includes a metal barrel.
The Eduard set is also very good.
KitMaker: 67 posts
Armorama: 38 posts
Posted: Thursday, February 04, 2010 - 01:35 PM UTC
Jason, Chris - thanks for the hint on those bolts! Almost missed them on my Leo... LOL
Good thing I havent put any primer on it yet. Seems like an easy fix...
Rick, I had exactly same idea about Barracuda on Hobby Boss kit! Should work just fine!
BTW
I know most of you guys got the Camo netting from Lawrence already, but just in case somebody is still interested - I have those in stock. Tan color to match Barracuda tones.
Can be purchased on its own or with Leo upgrade set.
Cheers!
Andy
KitMaker: 7 posts
Armorama: 6 posts
Posted: Thursday, February 04, 2010 - 09:30 PM UTC
Looking forward to starting my Leo2A6M. Thanks Andy for the quick response to my request, looking forward to the conversion and decals.
Looking forward to seeing some building.
Posted: Friday, February 05, 2010 - 10:55 AM UTC
Posted: Saturday, February 06, 2010 - 12:58 PM UTC
Does anyone know where I can find the Big Ed set in the states? Everyone seems to be out of stock
I received: Tamiya Leopard 2A6, Storm Miniatures detail set with decals and camo netting.
On the Way: Tow Cables, ARMO Barrel
Need: Eduard Big Ed 2A6M set.
KitMaker: 25 posts
Armorama: 24 posts
Posted: Saturday, February 06, 2010 - 05:54 PM UTC
Can you explain the Barracuda cam. Is that a one-of?
