Hosted by Jacques Duquette
How to model a T-55
aremark
Arizona, United States
KitMaker: 18 posts
Armorama: 18 posts
KitMaker: 18 posts
Armorama: 18 posts
Posted: Sunday, September 17, 2017 - 04:20 AM UTC
Thanks guys for the info. I am still learning a lot about this tank. After looking at this site and some of the modeling I am truly impressed at the details people are putting into the models.
MichalBT
Województwo Kieleckie, Poland
KitMaker: 326 posts
Armorama: 275 posts
KitMaker: 326 posts
Armorama: 275 posts
Posted: Sunday, September 17, 2017 - 09:59 PM UTC
Andrew, an entire book could be written on what was produced in Poland concerning T-54/55's alone.
There are link1 and link2 to a very complex articles about Polish modifications of T-54/55- not only in Merida version.
Articles are in Polish- but You can try to use Google translator.
Hope it helps
Michal
JSSVIII
Massachusetts, United States
KitMaker: 1,169 posts
Armorama: 1,067 posts
Posted: Monday, September 18, 2017 - 04:18 AM UTC
thanks for those links Michal, very helpful! (with the use of Google tranlate of course.)
aremark
KitMaker: 18 posts
Armorama: 18 posts
KitMaker: 18 posts
Armorama: 18 posts
Posted: Monday, September 18, 2017 - 08:37 AM UTC
I agree these links are great! Thanks Michal
aremark
KitMaker: 18 posts
Armorama: 18 posts
KitMaker: 18 posts
Armorama: 18 posts
Posted: Tuesday, September 19, 2017 - 08:50 AM UTC
Does anybody know what the rectangular blocks on the upper glacias next to the tow points are for? They are only on some T55 tanks. They look like an attachment rest or something, but I cannot find any pictures of them being utilized or described.
JSSVIII
Posted: Tuesday, September 19, 2017 - 03:36 PM UTC
I'm by no means an expert, but off the top of my head, I believe those have to do with mounting a mine roller system, you might try searching in that direction.
Jacques
Minnesota, United States
KitMaker: 4,630 posts
Armorama: 4,498 posts
Posted: Tuesday, September 19, 2017 - 05:42 PM UTC
If you are talking about the ones near the top of the glacis, they are used to bolt on the hydraulic cylinders for the Mine Plow systems.
aremark
KitMaker: 18 posts
Armorama: 18 posts
KitMaker: 18 posts
Armorama: 18 posts
Posted: Thursday, September 21, 2017 - 10:53 AM UTC
MichalBT
KitMaker: 326 posts
Armorama: 275 posts
KitMaker: 326 posts
Armorama: 275 posts
Posted: Thursday, September 21, 2017 - 09:35 PM UTC
These "rectangle stops" (together with "rectangular blocks") were used when tank was equipped with KMT-4/ KMT-5.
"Rectangle stops" were used to rescrict lift of mine roller. This time "rectangular blocks" were receiving handles to mount chains (which were connected with mine roller).
Hope this helps
Michal
Hope this helps
Michal
MichalBT
KitMaker: 326 posts
Armorama: 275 posts
KitMaker: 326 posts
Armorama: 275 posts
Posted: Thursday, September 21, 2017 - 09:46 PM UTC
aremark
KitMaker: 18 posts
Armorama: 18 posts
KitMaker: 18 posts
Armorama: 18 posts
Posted: Saturday, November 18, 2017 - 03:41 AM UTC
aremark
KitMaker: 18 posts
Armorama: 18 posts
KitMaker: 18 posts
Armorama: 18 posts
Posted: Saturday, November 18, 2017 - 03:48 AM UTC
I also wanted to show you an unusual part that you may care about if you ever want to set up a fording display. This is the fording exhaust valve. For fording, beyond putting on the snorkel and sealing the tank, this valve is bolted over the exhaust on the left side of the tank. The 2 circular doors can be locked open, but for fording they are closed with spring tension. When the engine is running the pressure from the exhaust opens the doors, provided the exhaust pressure is stronger than the spring and any water pressure against it. This way no water gets into the engine.
aremark
KitMaker: 18 posts
Armorama: 18 posts
KitMaker: 18 posts
Armorama: 18 posts
Posted: Monday, December 18, 2017 - 04:12 AM UTC
Does anybody know what is stored in the vertical rectangular container between the smoke grenade launcher and the ammo cans? I only see this storage box on T-55AM2 and even then it is not on all of them.
Inside the container is a bracket that appears to be made to hold two cylinder like objects. The bracket holes for the cylinder like objects are also two different sizes. So it is not two of the same thing, they are two different sized (minorly different sized) cylinder like objects.
seanmcandrews
KitMaker: 561 posts
Armorama: 553 posts
KitMaker: 561 posts
Armorama: 553 posts
Posted: Monday, December 18, 2017 - 07:28 PM UTC
I always assumed it was storage for smoke grenades, would love to see a photo of the inside. Here's info on the grenades themselves, may provide some evidence if that's what it's for.
http://dezamet.com.pl/files/files/en/pliki_do_pobrania/Dezamet_81_eng.pdf
Sean
Sean
guni-kid
Nordrhein-Westfalen, Germany
KitMaker: 521 posts
Armorama: 514 posts
KitMaker: 521 posts
Armorama: 514 posts
Posted: Monday, December 18, 2017 - 07:46 PM UTC
It's probably the storage container for the disassembled laser warning device... Correct me, if I'm wrong, because I'm also not 100% sure. (The laser warning device is the bar-shaped dome behind the commanders cupola)
seanmcandrews
KitMaker: 561 posts
Armorama: 553 posts
KitMaker: 561 posts
Armorama: 553 posts
Posted: Monday, December 18, 2017 - 08:29 PM UTC
Another good guess, although I believe it's a meteorological sensor.
Sean
Sean
aremark
KitMaker: 18 posts
Armorama: 18 posts
KitMaker: 18 posts
Armorama: 18 posts
Posted: Tuesday, December 19, 2017 - 10:24 AM UTC
Sean
We thought about smoke grenades but decided it was not quite right. I will get pictures of the inside this weekend.
guni-kid
KitMaker: 521 posts
Armorama: 514 posts
KitMaker: 521 posts
Armorama: 514 posts
Posted: Tuesday, December 19, 2017 - 01:53 PM UTC
Sean
You might be right... the laser warning device could also be installed at the upper mantlet. I assumed, though, that the laser device above the mantlet/barrel would be the active part, i.e. the laser range finder... Will have a look into my "Kampfpanzer der NVA" book in the evening and check if I can find out more
aremark
KitMaker: 18 posts
Armorama: 18 posts
KitMaker: 18 posts
Armorama: 18 posts
Posted: Tuesday, December 26, 2017 - 07:50 AM UTC
Inside pics of the storage box.
guni-kid
KitMaker: 521 posts
Armorama: 514 posts
KitMaker: 521 posts
Armorama: 514 posts
Posted: Friday, December 29, 2017 - 10:21 PM UTC
I checked my books and can say:The round device behind the cupola is the laser warning device. So my guess stands: The container might be the storage container for the disassembled laser warning device... since it's a rather fragile optical device (and therefor probably expensive) it might be in there when not in use...
aremark
KitMaker: 18 posts
Armorama: 18 posts
KitMaker: 18 posts
Armorama: 18 posts
Posted: Saturday, December 30, 2017 - 04:35 AM UTC
I'll check it out, but that tower is bolted together, no quick detach. And I forget if the electrical has an easy disconnect. I know it has a bracket that is screwed in and holding the electrcial line which prevent pulling on the electrical line. The tower does have a quick release to tilt it down and out of the way for low clearance. I'll post photos later.
aremark
KitMaker: 18 posts
Armorama: 18 posts
KitMaker: 18 posts
Armorama: 18 posts
Posted: Saturday, December 30, 2017 - 06:47 AM UTC
Here are some pictures with the laser detector down and up. I will have my friend look closer at the unit tomorrow.
aremark
KitMaker: 18 posts
Armorama: 18 posts
KitMaker: 18 posts
Armorama: 18 posts
Posted: Sunday, December 31, 2017 - 01:07 PM UTC
We checked, the laser detector and wind sensor tower is too big in too many ways to fit in the box.
guni-kid
KitMaker: 521 posts
Armorama: 514 posts
KitMaker: 521 posts
Armorama: 514 posts
Posted: Monday, January 01, 2018 - 01:24 AM UTC
Alright back to square one then, I guess Now I'm also quite interested in what the container is actually there for...
Removed by original poster on 02/27/18 - 22:53:16 (GMT).
