Яusso-Soviэt Forum
T-55 Enigma
Spiderfrommars
Milano, Italy
KitMaker: 3,845 posts
Armorama: 3,543 posts
Posted: Sunday, October 16, 2011 - 07:38 PM UTC
Thank you Olivier
bison126
Correze, France
KitMaker: 5,329 posts
Armorama: 5,204 posts
Posted: Saturday, October 22, 2011 - 12:56 AM UTC
Hi all,
the build is complete. I added some details missing on the Tamiya kit. What bothers me the most is the engine deck that Tamiya have oversimplified.
I added some bits of plastic card to improve it but it still is not 100% accurate. For instance the wading rail is too large but it's too late to make a new one.
Here are the pictures.
I'd like any advise about a correct color for an GW1 Iraqi tank. I use the Tamiya range so I guess the base would be Desert Yellow plus something else.
TIA
Olivier
TIA
Olivier
Spiderfrommars
Milano, Italy
Posted: Saturday, October 22, 2011 - 03:05 AM UTC
Well done Olivier, engine deck looks great
Regarding the pale sand color if I were you I'd use tamiya xf 57 buff
I imagine that you'll weather a lot your tank so starting from a light base would be perhaps better than having a darker base color (such as the xf 59)
Otherwise you could use xf 59 faded with a bit of white
My two cents anyway
My two cents anyway
spiritwalker
England - North, United Kingdom
KitMaker: 99 posts
Armorama: 97 posts
KitMaker: 99 posts
Armorama: 97 posts
Posted: Saturday, October 22, 2011 - 03:21 AM UTC
Hi Olivier
it is a tight squeeze getting the wading rail to sit in between the air filter cover and the radiator torsion bar hinge... only thing i can add about your buyild is that there should be a notch cut out of the engine hatch plate where the fuel pipe inlet vent is located..
Andy
Andy
Spiderfrommars
Milano, Italy
Posted: Saturday, October 22, 2011 - 04:12 AM UTC
Hi Olivier
Andy
Hi Andy. Unfortunately as you probably know, in Tamiya kit there are a little space between the hinge and the hatches. Less than 1 mm. Correcting that flaw it would be rebuild the parte were are the engine hatches. I think that the tight sqeeze although is not perfect, is perhaps the best adjustment in my humble opinion
bison126
Correze, France
Posted: Saturday, October 22, 2011 - 04:17 AM UTC
Hi Olivier
Andy
Thanks for the comment Andy. If I understand well what you mean about the notch cut out, you can see it on this picture.
Maybe it is not deep enough.
Mauro, you're certainly right about Buff being a good starting point. But I didn't intend to depict a battle-worn tank. The Enigma being a command tank, if I'm correct, I think it should have been well maintained.
Olivier
gizmo21
Noord-Holland, Netherlands
KitMaker: 209 posts
Armorama: 155 posts
KitMaker: 209 posts
Armorama: 155 posts
Posted: Saturday, October 22, 2011 - 07:15 AM UTC
good job oliver
overall it looks very good.
Let see some paint
chris
Let see some paint
chris
dvarettoni
South Carolina, United States
KitMaker: 778 posts
Armorama: 763 posts
KitMaker: 778 posts
Armorama: 763 posts
Posted: Saturday, October 22, 2011 - 07:24 PM UTC
olivier another great build I have one question did the kit come with the reservoir for the driver para-scope if so can you post the measurements for me I'm going to
build one for you T-62 thanks
dave
dave
bison126
Correze, France
Posted: Saturday, October 22, 2011 - 08:43 PM UTC
Thanks Dave.
Here are the reservoir dimensions :
length 15mm
height 3.5mm
width 1.8mm
tabs (on the side for the bolts) 1.2 x 1.2mm
Olivier
length 15mm
height 3.5mm
width 1.8mm
Olivier
dvarettoni
KitMaker: 778 posts
Armorama: 763 posts
KitMaker: 778 posts
Armorama: 763 posts
Posted: Saturday, October 22, 2011 - 10:54 PM UTC
thanks this will help a lot olivier
dave
dave
bison126
Correze, France
Posted: Friday, November 11, 2011 - 09:24 PM UTC
Hi all,
I finally put some paint on it. The shade is close to the Tamiya Buff. I brushed a filter of Sienna earth over the whole model before applying some Umber earth as pinwash.
The result is a bit too rusty considering my initial intent.
The tracks are not fully weathered yet. The exhaust still needs to be darkened and I'll apply some dust to show an operational tank but not a piece of scrap.
Olivier
Olivier
Spiderfrommars
Milano, Italy
Posted: Friday, November 11, 2011 - 10:13 PM UTC
Looks very good Olivier
Probably it would be perfect with a darker pin wash but is just my opinion
Congrats
Congrats
Citizinsane
KitMaker: 463 posts
Armorama: 450 posts
KitMaker: 463 posts
Armorama: 450 posts
Posted: Friday, November 11, 2011 - 11:05 PM UTC
man Olivier,
that's really nice! I'll second what Mauro said, maybe try 502ABT's 'shadow brown' you could also try to sprinkle on some darker dots with a greyish color via toothbrush to break up the surfaces even more. maybe some dark-yellow oil applications around the shadow areas could look good as well...
other than that I really like the rusty appearance, haven't seen many pics of these but the ones I've seen did look just like your model! thumbs up!
Cheers, Max
Cheers, Max
dvarettoni
KitMaker: 778 posts
Armorama: 763 posts
KitMaker: 778 posts
Armorama: 763 posts
Posted: Saturday, November 12, 2011 - 01:42 AM UTC
any other great build all i can say is wow
dave
dave
seb43
Paris, France
KitMaker: 2,315 posts
Armorama: 2,158 posts
Posted: Saturday, November 12, 2011 - 04:58 AM UTC
SuPer great paint job
For me is a good paint job but I am not a super paint expert.
Chhers
Seb
Chhers
Seb
bison126
Correze, France
Posted: Sunday, November 13, 2011 - 06:37 AM UTC
Hi all,
here is the last batch of pictures and the final post on this Blog. The rest of the story can be read on my site.
Olivier
Olivier
17741907
Istanbul, Turkey / Türkçe
KitMaker: 953 posts
Armorama: 705 posts
KitMaker: 953 posts
Armorama: 705 posts
Posted: Sunday, November 13, 2011 - 12:03 PM UTC
Well done Oliver......
Spiderfrommars
Milano, Italy
Posted: Sunday, November 13, 2011 - 06:33 PM UTC
Now it's simply perfect
Well done Olivier!
Well done Olivier!
jointhepit
Oost-Vlaanderen, Belgium
KitMaker: 3,829 posts
Armorama: 881 posts
Armorama: 881 posts
Posted: Monday, November 14, 2011 - 01:23 AM UTC
Olivier brilliant Enigma, only needs some real sand and a donkey :)
just kiddin', it's cool on it's own!
