I building the Dragon/CyberHobby Panther G (Kit Number 6267) and I want an early G as I'm building the captured Panther = 'Cuckoo'... but as I have found out! and this is my first Dragon build the instruction are a little vague as to what parts to use!
For the Final drives is it the one with the rollers? which fans? mesh over the radiators etc... the list goes on, any help would be greatly appreciated! I know some of the late mods etc! but NOT the early set ups so just pile in and tell me!
Many thanks
Regards Duncan.
Early Panther g help!
Klinker
Tasmania, Australia
KitMaker: 369 posts
Armorama: 352 posts
KitMaker: 369 posts
Armorama: 352 posts
Posted: Tuesday, September 13, 2011 - 12:20 AM UTC
SdAufKla
South Carolina, United States
KitMaker: 2,238 posts
Armorama: 2,158 posts
Posted: Tuesday, September 13, 2011 - 02:00 AM UTC
Hi Duncan,
As it hapens, our AMPS chapter is doing a group-buid using the DML Panther G-series kits right now.
This link will take you to our home page and you can then tab over to our group-build page and down-load our build notes and tips from the links under Group Build 2:
AMPS Central SC "Wildcats"
The short answers on your particular build questions are:
Cuckoo was Zimmerited G model, so it was constructed before 7-10 Sep '44 (it also appears to me to have the "rough" stucco-like DB Zimmerit). Therefore, it should have the "early" G features:
Use the G4(G5) final drives with the A19 rollers. (The optional parts with the skids G24 are only for very late MNH factory production.)
For the fans, use parts D21 with more blades (than parts D5 with fewer blades). The D5 parts represent the later "strengthened" fan design.
Use the mesh over all the air intake and outlet openings. Do not use the C21 crew compartment heater assembly, but rather another A10 (A9) to match the right side.
Do not use the A27(A29) air intake louvers. These are only used with the crew compartment heater.
You should use the early larger idler wheel assembly, A30+A31, et al.
There's an error (as far as I can tell) on the DML torsion-bar / swing arm layout. The final two stations on each side should have the same torsion-bar / swing arms as the first station on each side (parts E2). So, in place of the E6(E7) parts, use extra E5 parts which are identical to the E2 parts. (You'll run out of E2's before you have enough to do all six stations, three on each side.)
Finally, use the E13 bumper stops. The E14 stops are the later design.
I'm sure that some real Panther experts can dial in some additional features that might be peculiar to your subject tank, but I think that the above list should get you through the worst of the DML "explanation-less-options."
Hopefully, we'll have some WIP photos of the group-build models up on our website by the end of this week.
HTH,
HTH,
Klinker
Tasmania, Australia
KitMaker: 369 posts
Armorama: 352 posts
KitMaker: 369 posts
Armorama: 352 posts
Posted: Tuesday, September 13, 2011 - 10:23 PM UTC
Thanks Mike exactly the information I was looking for, even down to the part numbers! = fantastic
I will check in on your group-build for sure.
Regards Duncan.
Regards Duncan.
