OK having found the answer to my initial question here I can now start this topic about this recently released kit.
The detail is basic as can be seen on the cabin pictures. Most of the parts have a prominent molding line or large ejection pin marks. So be prepared to do some tedious cleaning work before gluing anything.
The fit is quite good.
Here are some pictures.
First the undercarriage with the engine in place.
The troop compartment (partly weathered so far). It is intentionnally painted lighter than it should be as I'll only let the driver door open.
The cargo compartment
A test fit of the sub-assemblies.
It will be a bit larger than I expected. I'll paint it in the desert scheme proposed by Revell in the instructions so I first have to order the Vallejo set.
Olivier
Revell ATF Dingo 2
bison126
Correze, France
KitMaker: 5,329 posts
Armorama: 5,204 posts
Posted: Friday, January 17, 2014 - 03:12 AM UTC
afv_rob
KitMaker: 2,556 posts
Armorama: 2,199 posts
Posted: Friday, January 17, 2014 - 12:00 PM UTC
Nice work so far Olivier!
Revell appear to have produced a really rather nice kit here, the interior looks suitably busy to add some interest through the windows. Just might have to get one of these.
bat-213
Canada
KitMaker: 902 posts
Armorama: 788 posts
KitMaker: 902 posts
Armorama: 788 posts
Posted: Friday, January 17, 2014 - 05:59 PM UTC
great start on the dingo.cant wait to see it finished.
bison126
Correze, France
Posted: Friday, January 17, 2014 - 10:40 PM UTC
You're right Rob, it will do the trick through the windows. If you intend to open the doors, expect to have more detailing job as lots of things are simplified.
The dashboard is quite good with decals to give it some "life".
The inner padding is not present and Revell have you depicting it by painting the specific areas.
No seat belts are given. Here is some room for AM stuff.
Olivier
HermannB
Bayern, Germany
KitMaker: 4,099 posts
Armorama: 4,067 posts
Posted: Saturday, January 18, 2014 - 01:09 AM UTC
Hi Olivier, you right about the interior. Especially the 1530 weapons station need some details on the cranks and sights. For pictures, you can also refer to the weapons station on the Fennek.
Hans-Hermann
Hans-Hermann
Posted: Saturday, January 18, 2014 - 03:44 AM UTC
Nice start Oliver, watching with interest to see how this looks
Posted: Saturday, January 18, 2014 - 03:51 AM UTC
Nice job on the interior. The details are lifted nicely and are perfectly adequate. Would be an idea to add some personal stuff with a little colour, to add evn more interest.
bison126
Correze, France
Posted: Saturday, January 18, 2014 - 04:56 AM UTC
Hans-Hermann
Hi Hans-Hermann
I got a couple of pics takne in Afghanistan to help detailing a bit the gunner station.
For all interested in this vehicle, the kit wheels are too small. In 1/1 scale they would be 1050 mm diameter and 350 mm wide while they should be 1100 mm diameter and 365 mm wide. Thanks H-H
If a member could compare with the Real Models and the DEF Models wheels, it would be great.
Olivier
bison126
Correze, France
Posted: Sunday, January 19, 2014 - 04:05 AM UTC
Houston, erh Revell, we got a problem !
The roof definitely does not sit on the cabin.
Obviously it is the black duct which generates the problem. The bend in the part overlaps the rear wall.
I will have to do some surgery there.
Did another member also encounter this problem or did I mess the things up?
Moreover the four doors are bent so the glasses can't properly sit in their frame. Not hard to fix but a bit annoying.
Olivier
Olivier
AKirchhoff
Germany
KitMaker: 307 posts
Armorama: 304 posts
KitMaker: 307 posts
Armorama: 304 posts
Posted: Sunday, January 19, 2014 - 09:12 AM UTC
Hi!
I can confirm that you did not mess things up. Same problem with the turret roof during my build. I also shortened the duct to solve the problem. No problem that I do remember with the side doors in my kit.
Andreas
bison126
Correze, France
Posted: Sunday, January 19, 2014 - 06:57 PM UTC
Hello Andreas,I finally managed to fix the roof issue. I just cut the end near the rear wall by 1 mm and I put the roof in force.
It looks good now.
Concerning the doors, the upper part where you have to insert the glasses is bent outward. It is not hard to fix by glueing the doors to the cabin but the "damage" definitely prevents to let a door open.
I have some bad experience with trying to reshape a plastic part with heat. Unlike resin, plastic doesn't give you another opportunity if you fail the first time.
What do you think of the weapon station sights and controls? From the pictures I have, it is a total failure. I just added the controls and the rubber protections for the eyesights which can be visible through the gunner hatch but I think an AM part is a need/must if you intend to let the rear doors open.
Olivier
It looks good now.
Olivier
AKirchhoff
Germany
KitMaker: 307 posts
Armorama: 304 posts
KitMaker: 307 posts
Armorama: 304 posts
Posted: Monday, January 20, 2014 - 03:09 AM UTC
Hi Oliver,
I must confess that this was an OOB build for me only, I was not so much looking for mistakes. I clearly recognized the areas where the fit was not to optimum, and I myself was not really satisfied with the rear of the trunk section which could have been created a little nicer when it comes to the fit of the top canvas and the canvas rear. Can also be seen on your pictures. However, I did realize that the kit is a little basic in areas (as is the weapon station) but I know it is a Revell kit, and since I built PzH2000 with all its crude and basic details and the horrible tracks, I was quite satisfied with the Dingo as it is one of their better kits IMO. But, there is plenty room for improvement AM parts as you said. Lets see how long it takes until the first improvement set enters the market!
Andreas
Andreas
Andreas
Andreas
Paulinsibculo
Overijssel, Netherlands
KitMaker: 1,322 posts
Armorama: 1,239 posts
Posted: Monday, January 20, 2014 - 04:36 AM UTC
Bonjour, Olivier,
Quite recognisable, these not too well fit problems in Revell's program. And a pitty indeed, since they produce nice models, esp. those from the Bundeswehr. (not to speak about their rather strange policy of availability).
I faced some wrapping challenges with my MAN 5t.
To solve the wrapping of some parts, you may try very hot water. I used water that was near to the boiling point.
Leave it there, until you are sure that the temperature of the parts is realy warm. Now, you may carefully try to bend them into the right form. As this is done, put them in cold water. By using water, a more equal and controlled weakening of the plastic is realised, without any risk of, literally, burning or melting your parts.
No need to warn you about the risks of hot water ( I guess, while stating this I will be freed from any US lawyer )
retiredyank
Arkansas, United States
KitMaker: 11,610 posts
Armorama: 7,843 posts
Posted: Tuesday, January 21, 2014 - 09:19 AM UTC
Bonjour, Olivier,
"You mean my fresh cup of coffee is hot!?"
bison126
Correze, France
Posted: Saturday, January 25, 2014 - 05:56 AM UTC
Hi all,
here are some more pictures. The cabin, the cargo and the engine hood are dry fitted onto the chassis to have an idea of the final result.
For your information, some details are really basic to say the least. Just have a look at the mirrors supports which are molded solid with the back of the mirrors !
The build is nearly complete. I'm now waiting for the Vallejo ISAF paint set to arrive to start painting.
By the way, I could get my hands on the actual Dingo dimensions and compare them with the kit ones. Revell have done a great job dimension wise. The only flaw is the size of the tires. While the rim is correct, the tire is not large enough. The tire diameter should be larger of 1.4 mm in 1/35 scale.
Olivier
Olivier
retiredyank
Posted: Saturday, January 25, 2014 - 07:34 AM UTC
Hopefully, the am people will pick up on such an interesting kit. I can already see that I would have to separate the mirrors and rebuild the mounting hardware.
bison126
Correze, France
Posted: Saturday, January 25, 2014 - 09:35 PM UTC
Matt,
You're right about the AM guys. I gave the tip about the wheels so one can check which resin set is the best between Real Models and DEF Models.
I'd love seeing the FLW 200 EWS in resin. It would need a modified interior so the price would certainly be a bit high but the look of it is way more aggressive than the original weapon station.
HermannB
Bayern, Germany
Posted: Saturday, January 25, 2014 - 10:07 PM UTC
Hi there,
installing te FLW 200 is not as easy. On the real truck, a different hatch for reloading the weapon is installed, The FLW is mounted on a pedeatal in front. In best case a whole new roof is required.
bison126
Correze, France
Posted: Sunday, February 23, 2014 - 03:38 AM UTC
Hello all
I forgot to post some pictures of the painting stage.
Here are some of the Dingo nearly ready to roll out for patrol.
The wheels are just in place for the pics as I still don't know whether or not I put sagged resin ones.
The colors are from the Vallejo Umtarnfarben set. I don't like them as they tend to clog my AB but they are true to the RAL ones.
Olivier
Olivier
mvaiano
Sao Paulo, Brazil
KitMaker: 1,054 posts
Armorama: 1,050 posts
Posted: Sunday, February 23, 2014 - 04:33 AM UTC
Really nice!
I love this paint scheme.
Cheers!
Marco
Cheers!
Marco
rogerjo1
Västra Götaland, Sweden
KitMaker: 950 posts
Armorama: 905 posts
KitMaker: 950 posts
Armorama: 905 posts
Posted: Sunday, February 23, 2014 - 06:27 AM UTC
Nice build Olivier! Did you like the kit or was it like revell kit use to be? Bad fit and so on... But i like your model
chnoone
KitMaker: 1,036 posts
Armorama: 1,033 posts
Posted: Sunday, February 23, 2014 - 06:44 AM UTC
Wow !
You did a really good job on the camp !
Well done !
Christopher
Well done !
Christopher
35th-scale
Kildare, Ireland
KitMaker: 3,212 posts
Armorama: 2,807 posts
Posted: Sunday, February 23, 2014 - 10:56 AM UTC
Nice paint job and good recovery of the wing mirrors.
Just started my own this evening: remains to be seen if I managed to keep the chassis straight and level. It's a rather fiddley assembly.
bison126
Correze, France
Posted: Sunday, February 23, 2014 - 07:22 PM UTC
Thank you all for the comments.
The kit is Revell standard that is soft detail in some areas. This lets room for detailing. On my model the four doors were warped so gluing the clear windows was a bit challenging.
The build is not that hard but the chassis step is a bit tough and needs some attention to get the pieces straight. When it's done the rest of the build is quite straightforward.
Some modelers encountered some trouble when fitting the rear piece of tarp over the cargo compartment. This did not happen to me.
The molding lines can be huge especially on the chassis parts. And I would advise not to glue the rear foot-steps till the end of the painting step. Mine broke at least three times and I finally replaced them with some metal wire and plastic strips.
The interior is a good base. But again there is plenty of room for detailing.
Olivier
Olivier
flugwuzzi
Lower Austria, Austria
KitMaker: 633 posts
Armorama: 599 posts
KitMaker: 633 posts
Armorama: 599 posts
Posted: Tuesday, February 25, 2014 - 08:45 AM UTC
Nice build, Olivier!
Good to see you solved the duct-problem and the paintjob is nicly done.
I have to add another model to my wishlist ;-)
cheers
Walter
cheers
Walter
