Hi All!
I need info about the Friul ATL-153 track set.
What kind of guide horns are on the track links, hollow or solid ones?
I found no picture about it and the Friul website is not so informative.
Thank you!
Яusso-Soviэt Forum
Tunguska friul track question
mokush
Heves, Hungary
KitMaker: 216 posts
Armorama: 205 posts
KitMaker: 216 posts
Armorama: 205 posts
Posted: Wednesday, February 04, 2015 - 10:51 AM UTC
juge75
Jasz-Nagkyun-Szolnok, Hungary
KitMaker: 843 posts
Armorama: 841 posts
KitMaker: 843 posts
Armorama: 841 posts
Posted: Wednesday, February 04, 2015 - 12:25 PM UTC
Make that a lighter version of Friul , virtually the same as that shown in the box set as well.
The track is available in two versions of reality : Light and heavy (which is compatible with virtually Tor , Buk , Krug, Acacia ) , and fitted with rubber insert.
Different versions of the heavy rollers and idler pulley has been built , which was just practically , it is fitted .
Make that one side of the Friul -closed ( cast into the pin plug ) , drilled the other side , here is the right length of wire and screw closure in the cast plus one .
Acacia track:
Acacia track:
juge75
KitMaker: 843 posts
Armorama: 841 posts
KitMaker: 843 posts
Armorama: 841 posts
Posted: Wednesday, February 04, 2015 - 12:31 PM UTC
Sector 35 White Metal Tracks for 2S3 Acacia/Krug (Tor, Buk, Tunguska)
juge75
KitMaker: 843 posts
Armorama: 841 posts
KitMaker: 843 posts
Armorama: 841 posts
Posted: Wednesday, February 04, 2015 - 12:34 PM UTC
HADMODELS Running wheels this version:
mokush
Heves, Hungary
KitMaker: 216 posts
Armorama: 205 posts
KitMaker: 216 posts
Armorama: 205 posts
Posted: Wednesday, February 04, 2015 - 01:06 PM UTC
Szia!
Akkor, ha jól értelmezem, felhasználhatom 2s3 lánctalpát az általad készített futógörgőkkel. Jól értelmezem?
