Mk23 MTVR & 16.6 ton LHS
Posted: Saturday, January 21, 2017 - 11:29 AM UTC
I made this alteration to both the 16.5 ton 8x8 and the smaller 4x4 making later cab construction much easier.
Posted: Sunday, January 22, 2017 - 01:11 AM UTC
Posted: Sunday, January 22, 2017 - 01:35 AM UTC
Posted: Sunday, January 22, 2017 - 02:19 AM UTC
Posted: Monday, January 23, 2017 - 02:08 AM UTC
By any chance would someone have straight-on, photos or dimensional drawings for the Container Handling Unit (CHU)? Clearly overall dimensions of this lifting structure (less attachment hooks) must be 8 x 8 feet.
(Original CHU design shown in line drawing.)
(Enhanced design (E-CHU) shown in photograph.)
Posted: Saturday, January 28, 2017 - 09:32 AM UTC
Posted: Saturday, January 28, 2017 - 09:33 AM UTC
Posted: Sunday, January 29, 2017 - 02:46 AM UTC
DocEvan
KitMaker: 180 posts
Armorama: 180 posts
KitMaker: 180 posts
Armorama: 180 posts
Posted: Monday, January 30, 2017 - 07:36 AM UTC
We LIKE!
Posted: Wednesday, February 01, 2017 - 08:45 AM UTC
Many thanks Evan - - Mike
Posted: Friday, February 03, 2017 - 04:23 AM UTC
Another small detail that I just "HAD" to add to both the 4x4 and the 8x8:
The two mounting brackets under the hydraulic oil reservoir (just behind the cab) are supposed to be perforated. I think Trumpeter really should have added these two items to the PE sheet.
I used a twist drill to give myself a starting hole and then finished by enlarging the starting hole with a #11 E-Xacto blade.
Posted: Friday, February 03, 2017 - 04:24 AM UTC
For the finished tank I also needed to add the missing filler cap. A piece of sprue and a little bit of plastic rod did the job.
There will be input and outflow hoses added to the reservoir as well - more on this later.
Footnote: That small detail on each end of the reservoir is the sight glass for checking the fluid level.
___________________________________________________________________________________
For greater clearity I am going to split off the construction of the 4x4 bobber truck to a separate thread.
Here is the link to the new thread:
https://armorama.kitmaker.net/forums/255243
Posted: Monday, February 06, 2017 - 04:33 AM UTC
Posted: Monday, February 06, 2017 - 06:18 AM UTC
Posted: Monday, February 06, 2017 - 06:21 AM UTC
Posted: Wednesday, February 08, 2017 - 05:35 AM UTC
Posted: Thursday, February 09, 2017 - 02:26 AM UTC
Taylornic
Tennessee, United States
KitMaker: 337 posts
Armorama: 332 posts
KitMaker: 337 posts
Armorama: 332 posts
Posted: Friday, February 10, 2017 - 01:23 AM UTC
Those rear drives are a work of art. Very nice job!
Posted: Friday, February 10, 2017 - 01:54 AM UTC
Thanks Taylor. I think we can thank Oshkosh for the easy way these modular units go together, building block style. And it works equally well in both 1/35th and 1 to 1 scales.
Posted: Tuesday, February 14, 2017 - 08:28 AM UTC
KitMaker: 17,694 posts
Armorama: 13,742 posts
Posted: Tuesday, February 14, 2017 - 08:34 AM UTC
Nice job on the rear steering shaft.
Posted: Tuesday, February 14, 2017 - 09:57 AM UTC
Thanks Gino.
The only reference I have shows the rear steering shaft angling towards the passenger side of the cab. Therefore I have to assume it connects to the slave steering box up front.
Posted: Tuesday, February 14, 2017 - 11:33 PM UTC
Posted: Tuesday, February 14, 2017 - 11:40 PM UTC
Nice. Now what are you going to do with that extra HEMTT? I have a spare cargo bed if you want it. Just let me know.
Posted: Tuesday, February 14, 2017 - 11:41 PM UTC
Gino here is my plan for using the leftover HEMTT vehicle - a totally freelanced dump truck with a mid-ships mounted crane:
Now back to the LHS equipment:
This mechanism built by MULTILIFT of Britain is going to be a necessary addition for building my Mk ?? 16.5 ton Navy LHS.
Look at all that beautiful bolt head detail!
Very glad to report that the frame rail spacing on the HEMTT and the Mk23 IS THE SAME! (I think Oshkosh might have had a plan in mind here.) So the LHS MULTILIFT equipment drops right onto the Navy truck!
