Mannschaftstransportwagen Magirus ARW
St. Petersburg, Russia
KitMaker: 397 posts
Armorama: 397 posts
Posted: Tuesday, August 13, 2019 - 06:12 AM UTC
What you could do is to take a photo of the kit hull from the same angles as the original photos and compare the rounding of the hull.
I get the impression that the kit hull is fairly accurate in shape but it is difficult to compare when the angles and the lighting is so different ...
/ Robin
Tomorrow I will do a comparasion photos. I will add them here.
Best regards!
Artyom Nikolaev
KitMaker: 397 posts
Armorama: 397 posts
Posted: Tuesday, August 13, 2019 - 11:00 PM UTC
Best regards!
Artyom Nikolaev
RobinNilsson
TOS Moderator Stockholm, Sweden
KitMaker: 6,693 posts
Armorama: 5,562 posts
Posted: Tuesday, August 13, 2019 - 11:20 PM UTC
To my eyes the rounding between the top and the sides of the hull look good.
The corners that you have marked could possibly be a little to sharp on the kit. Those should be possible to sand down to make them softer/rounder, there should be enough resin there
I also get the impression that the rear edge of the wheel arch is almost a horizontal straight line on the real ARW but on the kit it curves slightly downwards to form sort of a point.
/ Robin
In memory of Al Superczynski:
"Build what YOU want, the way YOU want to....
and the critics will flame you every time"
KitMaker: 397 posts
Armorama: 397 posts
Posted: Tuesday, August 13, 2019 - 11:52 PM UTC
/ Robin
Yes. I think nothing critical. I will try to get corners rounder after I finish all works with welds. Indeed there are much enough resin there. If i fail I will use epoxy putty.
I have either impression about wheels arch. But I think I won't do anything about it. This work will be too complicated.
Best regards!
Artyom Nikolaev
Overijssel, Netherlands
KitMaker: 1,322 posts
Armorama: 1,239 posts
Posted: Tuesday, August 13, 2019 - 11:57 PM UTC
Artyom,
Beautiful build you share with us. Thanks.
Which supplier you took for these welds?
KitMaker: 397 posts
Armorama: 397 posts
Posted: Wednesday, August 14, 2019 - 12:04 AM UTC
Artyom,
Hello,Paul! Thank you! Very good that the vehicle is interesting for modellers
I often use Tamiya epoxy putty (quick type).
Best regards!
Artyom Nikolaev
Bayern, Germany
KitMaker: 4,099 posts
Armorama: 4,067 posts
Posted: Wednesday, August 14, 2019 - 01:49 AM UTC
If this is a Mannschaftstransportwagen or APC, I wonder how the dismounts get in and out?
CAD Images mean nothing.
What does a rivet counter count on a cast or welded tank hull?
RobinNilsson
Posted: Wednesday, August 14, 2019 - 02:51 AM UTC
Well, during those years the names used for various vehicles did not necessarily describe the real purpose of the vehicle.
Grosstraktor (to pull heavy stuff or maybe for very big farms),
Leichttraktor (to pull light equipment, maybe for airfields or for smaller farms),
Mannschaftstransportwagen (probably a new type of truck for transporting troops),
Battalionsführerwagen (some kind of staff car with space for more radios, probably somewhere in between a large PKW and a light LKW, definitely smaller than Montys armoured truck).
Later there were other euphemisms as well, such as "Arbeit macht frei" (my experience is that it usually makes sweat ...)
/ Robin
KitMaker: 397 posts
Armorama: 397 posts
Posted: Wednesday, August 14, 2019 - 11:40 PM UTC
By the way. Robin, what do you think was the turret box welded of it was casted with hull?
Best regards!
Artyom Nikolaev
RobinNilsson
Posted: Thursday, August 15, 2019 - 12:49 AM UTC
hmmmmmmmmmmm
going off on a wild tour into the dark forests of the Guessing Country ..............
1. This was a prototype.
2. I read somewhere that the specified weight limit was to be 7.5 tons and the armour was specified as 13.5 mm
3. The rims were cast from some kind of light metal alloy to keep the weight down.
Casting something large is one thing, casting something large and with thin walls, 13.5 mm thick sides of a casting that is somewhere around 5.5 meters long is more difficult.
My guess is that the hull was not cast at all except maybe for small pieces. If I were to build such a prototype I would use steel plates. For the full scale production it might be better to use casting but considering the shapes of the hull it could still be easier to shape steel plates and weld them together. Maybe it was even a simple armoured box with rounded ends and the fancy shapes over the wheels was only thin sheet metal.
The welds you have made under the wheel arches:
would fit the armoured box theory. The flat sides is the armoured box and the rounded shapes on the outside are there to increase volume to try and meet the original requirement that the ARW should float ...
Maybe you have already seen this page:
http://aviarmor.net/tww2/armored_cars/germany/arw.htm The answer to your question: My guess is that almost the whole thing was welded. Don't know what I should say about the turret though ...
/ Robin
Loire-Atlantique, France
KitMaker: 2,433 posts
Armorama: 2,325 posts
Posted: Friday, August 16, 2019 - 12:03 AM UTC
Really nice detailing work, built that kit myself, but straight from the box.
KitMaker: 397 posts
Armorama: 397 posts
Posted: Friday, August 16, 2019 - 01:04 AM UTC
hmmmmmmmmmmm
/ Robin
Thank you Robin for detailed aswer. I tend to agree with all your conclusions. For me it is much more easier to to do all these welds on a model.It will need time, of course. I have done only about 30% or less. Seems to me that turret is overall welded too. Much work ahead. But I have an expirience from former projects.
Best regards!
Artyom Nikolaev
KitMaker: 397 posts
Armorama: 397 posts
Posted: Friday, August 16, 2019 - 01:07 AM UTC
Greetings, Christophe! Sometimes building OOTB is a better way.
Sometimes I regret getting into such "resin adventure"
Best regards!
Artyom Nikolaev
KitMaker: 397 posts
Armorama: 397 posts
Posted: Friday, August 23, 2019 - 12:04 AM UTC
Best regards!
Artyom Nikolaev
RobinNilsson
Posted: Friday, August 23, 2019 - 12:16 AM UTC
Those welds look very realistic
KitMaker: 397 posts
Armorama: 397 posts
Posted: Friday, August 23, 2019 - 12:55 AM UTC
Thank you,Robin! Do my best.
Best regards!
Artyom Nikolaev
New South Wales, Australia
KitMaker: 1,476 posts
Armorama: 1,463 posts
Posted: Friday, August 23, 2019 - 11:44 PM UTC
KitMaker: 397 posts
Armorama: 397 posts
Posted: Sunday, August 25, 2019 - 08:53 AM UTC
Thank you Tim! You are too kind! Modesty is something what makes us stronger and skills better.I hope next week I will finish working with welds on hull. Remember that turret is welded too.
Best regards!
Artyom Nikolaev
KitMaker: 397 posts
Armorama: 397 posts
Posted: Thursday, August 29, 2019 - 01:49 AM UTC
Best regards!
Artyom Nikolaev
KitMaker: 397 posts
Armorama: 397 posts
Posted: Wednesday, September 11, 2019 - 02:18 AM UTC
Best regards!
Artyom Nikolaev
KitMaker: 49 posts
Armorama: 41 posts
Posted: Wednesday, September 11, 2019 - 04:05 AM UTC
That's one ugly vehicle, and it doesn't appeal to me at all, but I must say the kit looks like one superb job of casting.
KitMaker: 397 posts
Armorama: 397 posts
Posted: Wednesday, September 11, 2019 - 06:33 AM UTC
I think it has it is own beauty but my expectations about this kit were not fulfilled.
Best regards!
Artyom Nikolaev
Bangkok, Thailand / ไทย
KitMaker: 1,617 posts
Armorama: 1,150 posts
Posted: Wednesday, September 11, 2019 - 04:32 PM UTC
For that time period the vehicle was IMHO years ahead as we speak of design.
I new the Magirus design and it's appearance in real time. Very special and very different. I like it.
Kind regards,
Robert Jan
KitMaker: 397 posts
Armorama: 397 posts
Posted: Wednesday, September 11, 2019 - 11:57 PM UTC
Kind regards,
Robert Jan
Indeed. Design was too modern and production was too complicated.
Best regards!
Artyom Nikolaev
KitMaker: 397 posts
Armorama: 397 posts
Posted: Friday, September 27, 2019 - 01:40 AM UTC
Best regards!
Artyom Nikolaev
