Constructive Feedback
Panther finished,please take a look!
PanzerKarl
KitMaker: 2,439 posts
Armorama: 1,980 posts
Posted: Friday, September 10, 2004 - 08:28 AM UTC
I have just finished it about an hour ago,been on it since i got in from work.Its a DML panther F painted with Tamiya acrylics and mig pigments.no after market stuff was used,the tracks are the indy ones that came with the kit,easy to put the tracks together now i have the hang of it.comments welcome,please be kind :-) cheers
winchweight
KitMaker: 513 posts
Armorama: 291 posts
Posted: Friday, September 10, 2004 - 05:15 PM UTC
Looks great. I like the cammo scheme. Just one comment though, the rear photo shows that the corners above the storage bins on the back, have bright, clean unweathered paint. This area would trap grime etc. Good effort though.
Henk
KitMaker: 6,391 posts
Armorama: 4,258 posts
Posted: Friday, September 10, 2004 - 07:06 PM UTC
Nicely muted dapple camo Karl. Usualy the dapple schemes look as if they come straight from the factory.
Two tips to help make things even better. The towcable seems to be resting on the front mudguard, but the hook which would attatch to the hull seems to be molded to the cable eye? And on the subject of pictures, try not to take them with flashlight or a single lightsource closeby as it creates very dark, strong shadows. If you can't take the pic's outside (overcast, grey day is best) try to use light from two or three directions, or even better use a fluoresend light (striplight) but make sure to correct the white balance on your camera if neccesary.
Good luck with the next one
Henk
PLMP110
Alabama, United States
KitMaker: 1,318 posts
Armorama: 837 posts
Posted: Friday, September 10, 2004 - 09:26 PM UTC
Really good work. A few little things to help, if I may. Inside the muzzle should be black. Around the hull MG, raw paint is visible. The cursed gray DML plastic shows every time. These little touches make a good model great.
Patrick
slodder
KitMaker: 11,718 posts
Armorama: 7,138 posts
Posted: Friday, September 10, 2004 - 10:13 PM UTC
Looks good overall. I like the camo pattern and the colors used.
Couple of things - the jack, spare tracks, and tow cables look to monotone, clean, and aluminum color to me. The inside of the barrel needs to be painted black.
