Yesterday I had a first run of Vallejo clear matt on my M47. The hull turned matt, but the turret turned gloss. I'm thinking to use Dullcote. Any suggestion on how much it has to be diluted?
Ciao
Do you dilute Testors Dullcote?
scoccia
KitMaker: 2,606 posts
Armorama: 1,721 posts
Posted: Thursday, March 27, 2003 - 07:19 PM UTC
warlock0322
KitMaker: 1,036 posts
Armorama: 153 posts
Posted: Thursday, March 27, 2003 - 08:05 PM UTC
Can't really say for sure about the dilution, but Testors has dull coat in a spray can that works really well. No mixing and cleaning. Just point and spray..
scoccia
Posted: Thursday, March 27, 2003 - 08:39 PM UTC
Thanks Warlock,
but unfortunately that can is not available here in Italy...
Ciao
Ciao
AJLaFleche
KitMaker: 8,074 posts
Armorama: 3,293 posts
Posted: Friday, March 28, 2003 - 01:01 AM UTC
I ususally mix 25 % thinner when the bottle is new. As it ages, and the carrier starts to evaporate a bit, it may need an increase to aboout 50%. I use plain old paint thinner from the hardware store and this has served me fine for 20 years.
GunTruck
KitMaker: 5,885 posts
Armorama: 3,799 posts
Posted: Friday, March 28, 2003 - 03:30 AM UTC
Just like John in the above post - I always dilute Testors Dull Cote. I dilute 50% with Lacquer Thinner.
Also, if you spray the stuff on, undiluted and full-strength, and get the white frosting, you can clear this problem up by misting on clean Lacquer Thinner over the offending areas. Go slowly and be careful, but you can recover from this problem too.
Gunnie
Gunnie
Posted: Friday, March 28, 2003 - 03:36 AM UTC
My question is:
do you do the same with Humbrol matt varnish or is there an other way for that. I want to spray a later matt varnish over a tank. Is the diluting method the same as with the normal humbrol enamel paints???
scoccia
Posted: Friday, March 28, 2003 - 06:26 AM UTC
Thanks everybody for the prompt answers. As soon as I read Al's post I headed straight away to the local hobby shop and got Dullcote. I diluted about 50% (you never know if the products are exactly the same everywhere) and sprayed it on the turret, that in a few minutes turned to a perfectly matt finish. The funny thing is that hull & turret base coats and washes were just identical, they dried for abot 48 hours, and when I sprayed the Vallejo matt acryl on it on the turret turned gloss and not on the hull. Any Idea about the possible cause?
Ciao
Ciao
