Constructive Feedback
WIP Leopard 1A5 BE
ADNeate
KitMaker: 93 posts
Armorama: 92 posts
Posted: Thursday, November 15, 2007 - 10:41 AM UTC
Nevermind they look proportional. I hope to build another Leopard C2 to the same level of accuracy that you've achieved on your 1A5 BE, I got another base kit on the way for my C2.
ptruhe
KitMaker: 2,092 posts
Armorama: 1,607 posts
Posted: Thursday, November 15, 2007 - 12:49 PM UTC
Great job on the skirts.
LeoCmdr
KitMaker: 4,085 posts
Armorama: 3,917 posts
Posted: Thursday, November 15, 2007 - 08:12 PM UTC
Your build is coming along very nicely...keep up the good work.
Andrew, the basic Leopard 1 A1 and the 1 A2 turrets did not have the Blohm and Voss add-on armour added....it is only two sided rubber with thin armour steel plates in between....not Lexan. There was no need to add it to the 1 A2 turret because the 1 A2 turret was the only version with thicker armour built in when the turret was cast.
The MEXAS on the Leopard 1A6BE and the Canadian Leopard C1 and C2 is the same...just different shaped modules...MEXAS is MEXAS.
RoelGeutjens
KitMaker: 410 posts
Armorama: 383 posts
Posted: Tuesday, November 20, 2007 - 05:33 AM UTC
Hey guys
Thanks for the kind words! They are encouraging! I finished the hull this weekend. But I was able to take some pics only today
Next up is starting the turret!
The pics:
Any comment is welcome
Grtz Roel
The pics:
Grtz Roel
ptruhe
Posted: Tuesday, November 20, 2007 - 05:26 PM UTC
Can't wait for the turret and the SABCA unit.
What reference shows the revised tow cable mounts on the engine deck?
Posted: Thursday, November 22, 2007 - 01:34 AM UTC
Looks good, Roel
Your scratch building skills are very good and your additions will certainly make for an original Leo.
Looking forward to see more
RoelGeutjens
KitMaker: 410 posts
Armorama: 383 posts
Posted: Thursday, November 22, 2007 - 09:30 AM UTC
Good evening guys thanks very much for the comments! You need that once in a wile
@ Paul: I'm still thinkng how to build the sabca unit but I'll manage I hope! The reverse cable is like that on every Leopard 1A5BE. I made a 150 walkthrough photo shoot of the Leopard 1A5BE in my army unit!
@ Jesper: Thanks buddy! I try to make it as accurate as possible this time.
Grtz
Grtz
RoelGeutjens
KitMaker: 410 posts
Armorama: 383 posts
Posted: Saturday, December 15, 2007 - 06:14 AM UTC
Hello everybody
It's been some time since I last posted here. Unfortunate my camera took adirect hit and is broken. That is way this update came so late. I had to borrow a camera to take these shots.
This is the first post about the turret. So let me fill you in what happened:
1.First I had to clean up the turret and remove a lot of flash. Talk about a time consuming work :-D
2.I filled up some holes at the back of the turret and adjusted some connection points.
3.The smoke dischargers were adjusted and I added a protection ring to the right.
4.The turret case at the back was adjusted and I added a small gutter made of aluminium.
5.The rings around the 2 hatches were adjusted.
6.I made protective caps over the pericsopes.
The lighter parts are from sanding these are not glue left overs. There is a rude drawing where the sabca unit has to come.
De pics:
I have to wait for a evergreen plate I ordered. But it will arrive some time soon!
Till the next time
Grtz Roel
De pics:
Till the next time
Grtz Roel
Martinnnn
KitMaker: 5,435 posts
Armorama: 2,762 posts
Posted: Saturday, December 15, 2007 - 06:36 AM UTC
Great work Roel!
ADNeate
KitMaker: 93 posts
Armorama: 92 posts
Posted: Saturday, December 15, 2007 - 07:02 AM UTC
Did you check to make sure the vision blocks on the commanders cupola are correct, turns out they are arranged incorrectly on the kit. There is a really excellent photo on the modern canadian vehicle discussion group which shows the correct layout. Check your references!
ptruhe
Posted: Saturday, December 15, 2007 - 07:10 AM UTC
What are the adjustments to the rings?
Looks like you put on the rain gutters as well. Can't wait to see how the SABCA looks.
RoelGeutjens
KitMaker: 410 posts
Armorama: 383 posts
Posted: Saturday, December 15, 2007 - 09:45 PM UTC
Hey
@ Martin thanks for the comment buddy!
@Andrew thanks for pointing that out. I checked all of my pictures. I think there is two who needs adjustment but I'm not 100% sure. Could you give me the link? I will check there.
@Paul There was a little ledge on both rings which I sanded away for good
and drilled some holes. These are for the machine gun mount.
Thanks for all the comments it keeps me going
Grtz Roel
Grtz Roel
ptruhe
Posted: Sunday, December 16, 2007 - 11:48 AM UTC
Here's the picture:
http://www.network54.com/Forum/169232/message/1196470887/Here%27s+a+photo
It looks like a picture from the Tankograd Leopard Early Years book.
RoelGeutjens
KitMaker: 410 posts
Armorama: 383 posts
Posted: Monday, December 17, 2007 - 02:30 AM UTC
Paul thanks for pointing out that picture. And andrew it's true the vision blocks are wrong. There is even 1 missing. But that is all corrected now the pics will follow tomorrow. Thanks for the help fellas
Grtz
Grtz
kevinb120
KitMaker: 1,349 posts
Armorama: 1,267 posts
Posted: Monday, December 17, 2007 - 02:36 AM UTC
Looks great, I like how the turret is shaping up nicely
RoelGeutjens
KitMaker: 410 posts
Armorama: 383 posts
Posted: Monday, December 17, 2007 - 11:13 PM UTC
I took a quick shot of the correct TC cupola. There was as Andrew pointed out a mistake in the kit version. The TC has 8 periscopes 7 in the ring and 1 a little forward. The kit only had 6 in the ring. The pic shows he correct way :-) You can see the protective ring laying beside the turret. It shows only 8 mounting points but it should be 9.
Thanks for the help and now back to the build :-D
Grtz
Grtz
ADNeate
KitMaker: 93 posts
Armorama: 92 posts
Posted: Monday, December 24, 2007 - 08:42 AM UTC
Glad to be of service in some way! The adjustment of the vision blocks went smoothly, it's unfortunate that the kit comes with such a stupid error like that. I didn't orginally think they had it wrong but Paul Fredenburg showed us the photo which cleared it up completly. Looking good!
Posted: Tuesday, December 25, 2007 - 08:23 AM UTC
Interesting to follow your build, Roel. The attention to detail is inspiring.
Thanks for sharing
Thanks for sharing
RoelGeutjens
KitMaker: 410 posts
Armorama: 383 posts
Posted: Thursday, December 27, 2007 - 10:38 AM UTC
Good evening all from Belgium :-)
I want to share the new pics that I have made today! What we've done is we made the GPS antenna behind the TC hatch. The ring was placed back on after correcting it in the previous posting! The gunshield is ready and the protective cloth over the gunshield has been updated with some wire. The kit detail was to bad!
The pics:
So that is everything for tonight hope to post soon!!
Grtz Roel
The pics:
Grtz Roel
RoelGeutjens
KitMaker: 410 posts
Armorama: 383 posts
Posted: Monday, November 24, 2008 - 05:17 AM UTC
Long time ago since I last posted on this thread. Unfortunatly this project came to a halt when I started my M-109A3 GN. A few weeks ago I restarted this kit. To make some room on my photobucket account I deleted previous images but not to worry I will post some new ones so you can all follow where I stopped last time. The hull is finished and I'm busy doing the turret right now not so easy since I have to scratch the entire Sabca gunners sight.
I will show you the kit first, two pics of the real tanks, and my progress where I stopped about a year ago so it will be easy to follow for everyone.
So let's get started shall we:
The German version:
The Belgian version:
Pics of the finished hull:
The turret:
That's all for now. Thanks for looking everyone and as always comments are welcome.
Greetings Roel
The German version:
The turret:
Greetings Roel
ptruhe
Posted: Monday, November 24, 2008 - 07:22 AM UTC
Very nice. Are those custom boxes on the back of the turret basket?
RoelGeutjens
KitMaker: 410 posts
Armorama: 383 posts
Posted: Wednesday, November 26, 2008 - 03:12 AM UTC
@Paul: Thanks for the comments. Those boxes are British style WW2 boxes from resicast. We use the same ones on our leopards to carry extra stowage equipment and food.
Grtz Roel
Grtz Roel
RoelGeutjens
KitMaker: 410 posts
Armorama: 383 posts
Posted: Saturday, November 29, 2008 - 01:15 AM UTC
Hello all
Monday a fellow modeler of my club made some new pics of the progress made last week on the turret. The sabca gunners sight is coming along very nice and is taken shape
The bad news is I will be abroad for the next 4 months so updates will be on halt since this is the last one. Hope you like the pics I included some of the real gunners sight to make it more clear.
The pics:
A lot of work has to be done yet. I hope to finish this beast when I return next year around april. You will be updated then I promiss :thumb:
Thanks for viewing and comments are welcome as always
Thanks Roel
The pics:
Thanks Roel
ptruhe
Posted: Saturday, November 29, 2008 - 05:17 AM UTC
Sweet. The best part of the conversion. The SABCA is looking great and thanks for the actual pictures.
barron
KitMaker: 666 posts
Armorama: 598 posts
Posted: Saturday, November 29, 2008 - 05:39 AM UTC
Hey Roel , no I never got to go to cat gunnery. My unit in Baumholder never got that honor. We really looked bad when the german unit got the new leo's and we still had the M60A3's. The 8th ID was the last ones to get anything new.
