The bogey wheels have a line down the middle of them. Are these mold lines and should be removed?
If so is there a quick and easy way to do this, without having to scrape, fill with putty and sand?
GG
QUESTION:Tamiya Sherman bogey wheel
generalgrog
KitMaker: 41 posts
Armorama: 37 posts
KitMaker: 41 posts
Armorama: 37 posts
Posted: Sunday, September 02, 2007 - 09:11 AM UTC
exer
KitMaker: 6,048 posts
Armorama: 4,619 posts
Posted: Sunday, September 02, 2007 - 09:17 AM UTC
The real wheel tires have seams too. However they should be nowhere near as prominent in 1/35. The easiest way to sand them is to pass a sanding stick over them. There are pics of Sherman wheels with chunks of rubber missing from rough treatment so you don't have to sand them to a smooth finish.
EDIT: here's a Canadian Sherman where you can see the seam on the spare wheels on the glacis front
exer
Posted: Sunday, September 02, 2007 - 09:33 AM UTC
Here's a close up of the wheel
Posted: Sunday, September 02, 2007 - 10:16 AM UTC
Hi Pat,
Nice pic was that taken in Sicily/Italy? Any idea which unit?
Al
Al
HONEYCUT
KitMaker: 4,002 posts
Armorama: 2,947 posts
Posted: Monday, September 03, 2007 - 01:37 AM UTC
Hi Pat,
Al![]()
Gday Al
From what I remember it is a Canadian unit. It is a high res picture from the archives normandie files... Hence the grouse close up from Pat
Brad
jjumbo
KitMaker: 2,012 posts
Armorama: 1,949 posts
Posted: Monday, September 03, 2007 - 02:10 AM UTC
Hi Pat,
Al![]()
Hey Alan,
This photo's been posted before, maybe the last 3-4 months.
IIRC, it mentioned which Canadian unit it was.
I'll see if I can find out which CAR it is and will PM you.
jjumbo
ericadeane
KitMaker: 4,021 posts
Armorama: 3,947 posts
Posted: Monday, September 03, 2007 - 02:44 AM UTC
While the pic of the unused wheel on the Cdn sherman glacis shows the seam, I think if you were to leave all 12 roadwheels with seams in place, it would look like you just forgot to remove them -- that seam would be worn of very quickly on a wheel in use.
For 1/35, I'd remove the seam every time. My two cents
marcb
KitMaker: 1,244 posts
Armorama: 1,226 posts
Posted: Monday, September 03, 2007 - 03:25 AM UTC
It looks like their are also seams on a 90 degree angle to the logitudinal seam. If you want to show one seam, you would need to add these as well IMHO. I'd say it's easiest to remove the kit seam and portray a "worn" wheel.
generalgrog
KitMaker: 41 posts
Armorama: 37 posts
KitMaker: 41 posts
Armorama: 37 posts
Posted: Monday, September 03, 2007 - 03:42 AM UTC
You know what there actually more to it than just the seam. As I started to work on the bogeys it turns out that the casting is off a bit. I.E. Even if you scrape the line off, that won't gauarantee an even(flat) surface. So ths means that I will have to first scrape off the line, then fix the uneveness with putty. (I am using the squadron green putty) Then I will have to sand it all down.
Uggg.... a lot of work. Any repacements out there? or any suggestions to make it easier?
GG
GG
shermanfreak
KitMaker: 380 posts
Armorama: 202 posts
Posted: Monday, September 03, 2007 - 06:32 AM UTC
South Alberta Regiment M4A4 taken in Normandy.
It's Major David Currie's tank "Clanky".
exer
Posted: Monday, September 03, 2007 - 06:42 AM UTC
There are lots of replacement wheels out there and while you're at it you could replace the bogeys too as they lack details such as the bolts on the bottom of the truck and the on the track skid.
I would go for the Tasca set which gives you the bogeys and wheels.
generalgrog
KitMaker: 41 posts
Armorama: 37 posts
KitMaker: 41 posts
Armorama: 37 posts
Posted: Monday, September 03, 2007 - 06:54 AM UTC
Yeah I found some bogey wheels from tank workshop..I'll check out the tasca site as well.
Thanks,
GG
Thanks,
GG
generalgrog
KitMaker: 41 posts
Armorama: 37 posts
KitMaker: 41 posts
Armorama: 37 posts
Posted: Monday, September 03, 2007 - 12:06 PM UTC
Quoted TextUggg.... a lot of work. Any repacements out there? or any suggestions to make it easier?
I took a look at the TASCA web site and and I think I wil take your advice, and replace the whole bogey set. Also the tracks look really good too. I may just order a set of the track links and replace them as well.
Thanks,
GG
