DML's Pzkpfw I Ausf A Mod w/Interior
KitMaker: 5,425 posts
Armorama: 4,659 posts
Posted: Sunday, September 30, 2007 - 04:15 AM UTC
Looking good! Going for #13 marking? Dan
Dan,
I think I'm going to go for the box-art finish for the "R6" from 6 Pz..Div actually.
Indiana, United States
KitMaker: 3,117 posts
Armorama: 564 posts
Posted: Sunday, September 30, 2007 - 07:30 AM UTC
Bill, you have convinced me to go out and get this one for my stash closet. It might even get moved up to the front of the build list.
Great job on your shading.
"Treat 'em Rough", Current Builds--Wingnut Rumpler
I am frequently seen with blood shot eyes from staying up past my nap time to get the right colour scheme on my latest WWI model?
Posted: Sunday, September 30, 2007 - 12:25 PM UTC
Thanks Carl, it's been a fun little kit to build.
Zimbabwe
KitMaker: 3,529 posts
Armorama: 588 posts
Posted: Sunday, September 30, 2007 - 12:48 PM UTC
That was a nice build. Looks to be an interesting kit as well. It does seem people get fixed on the Tigers, Panthers, and forget the little guys out there.
Thanks for sharing!
Manitoba, Canada
KitMaker: 1,021 posts
Armorama: 805 posts
Posted: Sunday, September 30, 2007 - 03:55 PM UTC
Very nice work.
It seemed she viewed guys on the same level as potatoes.
-Kyon
Posted: Monday, October 01, 2007 - 12:49 AM UTC
Thanks matt, appreciate the comments.
Baleares, Spain / España
KitMaker: 15 posts
Armorama: 14 posts
Posted: Monday, October 01, 2007 - 05:20 AM UTC
Nice, but the conducts from the motor to the exhausts are rubber, not metal. Hope to be constructive.
#003
Donegal, Ireland
KitMaker: 9,763 posts
Armorama: 7,444 posts
Posted: Monday, October 01, 2007 - 09:39 AM UTC
Hi Bill. Great to see you back with a Blog again. Ive been finding it hard to get inpsired, but this has been really enjoyable and just what the doctor ordered!
You just gotta love those Pzr 1s. I built the 3´n´1 version a few weeks ago, and am dying to get to the painting stage .. but Ive 2 pzr IVs already there ..... and getting the decals to sit down over viewing hatches has been hard on the nerves! Knowing the problems you´ve encountered, all I can say is great job so far. Thanks for taking the time to build this and share with us!
IPMS Stockholm
Posted: Monday, October 01, 2007 - 10:38 AM UTC
Guillem,
Thanks for the tip, I'll have to look into that. I'll admit to always assuming they were corrugated metal tubing, not rubber, given the temperatures of the engine exhausts. That and always seeing other builds with them depicted as metal. I don't doubt your tip, just want to confirm it before making the change.
Frank,
Thanks for the comments and glad to hear you've got your build going again, looking forward to seeing what you do with the little guy.
KitMaker: 58 posts
Armorama: 54 posts
Posted: Tuesday, October 02, 2007 - 08:58 AM UTC
Nice work indeed Bill - but take a closer look at the suspension girders - sorry !
Stirl
Posted: Tuesday, October 02, 2007 - 09:39 AM UTC
Stirl
Ah, nice catch but easy to fix. Just need to pop them off and swap them around to the other sides.
KitMaker: 1,339 posts
Armorama: 637 posts
Posted: Wednesday, October 03, 2007 - 02:54 AM UTC
Fine looking build Bill. I think this one will have to get picked up from the LHS..
Dave
Reporting in from New Hampshire
KitMaker: 58 posts
Armorama: 54 posts
Posted: Wednesday, October 03, 2007 - 05:16 AM UTC
Hope they "pop-off" easily Bill - you`ve made an excellent job of this kit so far - can`t wait to see the next stage !
Stirl
Posted: Wednesday, October 03, 2007 - 07:44 AM UTC
Thanks Dave for the comments!
Stirl,
I'll have to do it carefully, but should go smoothly...I hope!
I do appreciate very much you pointing out the mistake, I'll have to check the instructions to see if the diagrams are correct and, if they are, then I've got no excuse since I distinctly recall checking the alignment of the raised bars to be sure how they went but still managed to get them reversed on installation.
Posted: Saturday, October 06, 2007 - 11:36 AM UTC
Having received some feed-back from last week's progress (special thanks to Guillem Marti and Stirling Lowery!), I checked my references and determined that I indeed had two errors that needed to be corrected. The first deals with the exhaust pipes, these do in fact have flexible rubber hoses that connect the mufflers to the engine and are not metal as I'd originally thought and finished them. I painted them with some enamel Gunmetal to simulate and correct. The second error had to do with the suspension girder, somehow or other I got them turned around and installed them in reverse, so these were popped off and switched around. The tell-tale sign is the little raised bit, it should go toward the idler wheel to restrain the suspension springs and I didn't pay enough attention on the original installation. All fixed now though.
Next up was the initial round of weathering. I used the "dot" method of applying small dots of enamel paint and then using a brush dampened with thinner to blend and draw down the dots together over the base paint. I used three different colors in the dots, applying them one at a time and blending together before adding the next, to determine just how much and where the colors needed to go. I used Raw Umber, Afrika Grunbraun, and a 70/30 mix of Panzergray/Light Gray in that order. Once that was taken care of, I applied a pin wash of Burnt Umber to all the raised detail and around the weld lines and hatches.
I'll let that set for the evening and come back tomorrow with a "fresh" set of eyes to see what adjustments, if any, need to be made before moving on to the next phase of weathering the undercarriage and tracks.
Manitoba, Canada
Armorama: 805 posts
Posted: Saturday, October 06, 2007 - 03:09 PM UTC
It looks awesome with just that little bit of weathering. Makes me want to try the "dot" method on my tank.
-Kyon
Tennessee, United States
KitMaker: 140 posts
Armorama: 125 posts
Posted: Saturday, October 06, 2007 - 03:13 PM UTC
that looks great !
Thessaloniki, Greece / Ελλάδα
KitMaker: 172 posts
Armorama: 168 posts
Posted: Saturday, October 06, 2007 - 09:41 PM UTC
excellent job.
bravo!!!
petros
Posted: Sunday, October 07, 2007 - 03:45 AM UTC
Matthew, Alexander, Petros, appreciate your comments, almost finished!
Posted: Sunday, October 07, 2007 - 08:17 AM UTC
Seems I've hit a bit of snag...I thought I had some dullcoate on hand to be able to move on to the next step but fortunately not...so until I can get to the LHS to get some more, no progress will be made.
KitMaker: 881 posts
Armorama: 826 posts
Posted: Sunday, October 07, 2007 - 12:33 PM UTC
Looking great Bill the dot method you did really worked well on this grey i love the effect, i look forward to the final touches.
Ron.
Posted: Monday, October 08, 2007 - 01:29 AM UTC
Thanks Ron, managed to get hold of some stuff yesterday before the LHS closed, so some more pictures tonight.
Posted: Monday, October 08, 2007 - 04:17 PM UTC
Applied some pigment weathering to the running gear and the superstructure. I mixed up some Gulf War Sand and Dry Mud MIG pigments and applied with water, let it dry, then worked it over with stiff bristled brushes as well as some larger sable brushes depending. Since this particular vehicle is marked for the France 1940 campaign, I was looking for a dusty early summer type of look to it as a compliment to the Panzer Gray finish. After watching the wild Monday-night football game tonight though, it was tough to do more than just take the one shot.
KitMaker: 1,349 posts
Armorama: 1,267 posts
Posted: Monday, October 08, 2007 - 05:02 PM UTC
omg the game was incredible, just got home from the watering hole
Looks great Bill, I like the collection of packed dust in a few corners here and there. The markings came out excellent as well
On the bench:
Cyber Hobby Ferdinand (88 campaign)
1/350th Dragon USS Ticonderoga
Eduard 1/48 F6F-3 Hellcat
