D7 Armoured Dozer - Resicast
KitMaker: 14 posts
Armorama: 13 posts
Posted: Wednesday, April 30, 2008 - 09:11 AM UTC
Hi Alan
As far as I am aware they were hydraulic and any piping was protected by the armour plate formed around the rams. I have the unarmoured version (yet to build) and in that you have to connect the piping to the unprotected rams.
I do recall having one problem in installing the bottom dozer frame to the track carrier frames. If I recall you have to put the pivot pin in from between the main body and the track carrier frames, and the gap is quite narrow, especially when you are trying to line every thing up.
Not very good with the photos but here are a few.
For better views click on my photos.
KitMaker: 14,499 posts
Armorama: 11,675 posts
Posted: Thursday, May 01, 2008 - 05:06 AM UTC
Hi David,
Nice work on the dozer, thanks for the pics. I can see that getting things to line up will be a bit tricky, there are a few parts to coordinate at once lol, lol. Understand what you mean about the pivot pins, will have a few trial run to see how thinga might work best.
Al
'Action this Day'
Winston Spencer Churchill
KitMaker: 14 posts
Armorama: 13 posts
Posted: Friday, May 02, 2008 - 07:34 AM UTC
Al
Nice Centur Dozer. Who's conversion is that AA or Cromwell?
David
Posted: Friday, May 02, 2008 - 07:58 AM UTC
Hi David,
Thanks. The Centaur is the AA conversion set.
Al
'Action this Day'
Posted: Friday, February 06, 2009 - 07:26 AM UTC
Hi Guys,
well it's been just over 11 months since I opened the box on this one. I ran into a few problems mounting the tracks, got depressed and put it to one side whilst I though about it or forgot about it
Anyway, the recent snow kept me away from work for a few days so I decided to get it out and try again.
got the controls and seat mounted this evening and a little work done on the winch. Hard to believe it over a year ago since I started this
Al
'Action this Day'
KitMaker: 2,329 posts
Armorama: 2,110 posts
Posted: Friday, February 06, 2009 - 09:14 AM UTC
Great dozer Al I didnt know how i missed thiss one,
What you got planned for the dio for this hunk ?
the kit looks superb resicast do some superb kits
Art isn't just pritty pictures. It's an expression of human rage.
Myanmar
KitMaker: 4,011 posts
Armorama: 1,498 posts
Posted: Friday, February 06, 2009 - 02:41 PM UTC
Glad you're back on it.
I had a dream the other night. It was about various model kit mfgs. making affordable IM styrene kits of unusual subject such as this.
i watched a scale plastic figure crawl along the edge . . . of an exacto blade . . . that's my dream , it's my nightmare . . . . . . . crawling , slithering . . . . . along the edge . . . . . . of an exacto . . . . . blade . . . . and surviving
Posted: Friday, February 06, 2009 - 07:12 PM UTC
Morning James,
It's an unforgiving kit lol.lol, there isn't much room for error as the alignment and spacing of the wheels needs to be exact. Mine wasn't hence the track problem, but with some heat, glue and a lot of bad language I finally go the tracks on. I also managed to snap the axel pins on the rear drive wheels which didn't help matters.
The tracks are link and length, first time I'd tried those and each link has a very delicate top claw, a lot of which I broke off and had to add back on
Over confidence on my part and painting a couple of bits I should have left clean also caused me a few problems. All part of the learning experience!!
So....,
That sounds like a positive dream, I have similar connected with Bedfiord and 15cwt Trucks
Thanks for dropping in.
Al
'Action this Day'
Posted: Friday, February 06, 2009 - 10:06 PM UTC
Hi Guys,
Some updates from last night. Added the control levers, and the winch and tow hook. Fixed the RHS track!
Not 100% sure the tow bar is correct but seems to be from what I can find out.
Al
'Action this Day'
Posted: Friday, February 06, 2009 - 11:49 PM UTC
Sounds some what frustraighting alan
never the less she looks a great
But once the Armour is on wouldnt most of the dtail be hidden away?
Posted: Saturday, February 07, 2009 - 12:11 AM UTC
Hi James,
Very true, but good practice for when I get to the open top version
Al
'Action this Day'
Wisconsin, United States
KitMaker: 2,314 posts
Armorama: 1,905 posts
Posted: Saturday, February 07, 2009 - 12:13 AM UTC
Al
A beaut. Thanks for all the pics in this thread.
You are the master.
Steve
Posted: Saturday, February 07, 2009 - 02:47 AM UTC
Hi Steve,
Thanks, will have to see how the final build turns out, could all go wrong yet lol, lol.
Al
'Action this Day'
Posted: Saturday, February 07, 2009 - 08:48 PM UTC
Hi Guys,
Some updates on yesterdays progress.
Test fitted the blade last night, drilled out all the holes and checked the pins fitted. You can have the blade straight or at an angle and there is a nice bit of PE to add to the bottom. Also drill out a bit more the recess for the hydraulic arms.
Started on the under or belly armour and gave the inside a first coat of paint.
There are 3 bolt heads on the front chassis that will need to be removed/filed down prior to adding the armour.
Some pics
Al
'Action this Day'
Posted: Sunday, February 08, 2009 - 12:08 AM UTC
Alan i must say it looks superb! I really like dozerblad and the hydrollic rams
keep up the good work!
Victoria, Australia
KitMaker: 4,002 posts
Armorama: 2,947 posts
Posted: Sunday, February 08, 2009 - 12:09 AM UTC
Gday Al
Good to see this one making an appearance again!
Disappointed to hear it wouldn't fit on board, but I reckon it could prove to yield a dynamic scene on the sand with the blade in action
Brad
"There never was a good war, or a bad peace."
Benjamin Franklin
Posted: Sunday, February 08, 2009 - 01:51 AM UTC
Hi guys,
It's moving along. Undecided as to whether to put a driver in, leaning out the top or climbing up the side lol, lol.
Al
'Action this Day'
Posted: Tuesday, February 10, 2009 - 04:43 AM UTC
Hi Guys,
A few more updates. Drilled out the hydraulic arms a good bit more to give extra movement to the blade, test fitted the armour and added some small fitting there and to the winch.
To give you an idea of size here it is beside the MG Carrier
Al
'Action this Day'
Posted: Tuesday, February 10, 2009 - 05:46 AM UTC
I catn believe the size of it Alan!. It looks great its really coming along, take it no driver inside?
Posted: Tuesday, February 10, 2009 - 06:10 AM UTC
Hi James,
No driver inside at the moment. I have a figure on route but may show the driver standing up in the hatch, or climbing onto the vehicle. Silll undecided at the moment.
Al
'Action this Day'
Posted: Tuesday, February 10, 2009 - 06:14 AM UTC
Alan that is probably the best thing to do otherwise your not really going to see him although the top is open, Are you habing it in a diorama?
Posted: Tuesday, February 10, 2009 - 06:27 AM UTC
Hi James,
it's part of the builds for my Nan Red project that I will get to one day
Al
'Action this Day'
Posted: Tuesday, February 10, 2009 - 06:53 AM UTC
Nan reds project ? . whats that?
Posted: Tuesday, February 10, 2009 - 07:02 AM UTC
Hi James,
It's based around the landing of 48 RM Commando in support of the Canadian 3rd Infantry Dvision on Nan Red Beach on D Day.
Al
'Action this Day'
Posted: Tuesday, February 10, 2009 - 07:28 AM UTC
ahh cool
I dont know much about that so i will do some digging on the subject
