Work started off by addressing the area of the weld seams for the upper hull. Trumpeter, for some reason, elected to mold these as recessed weld lines when in fact they should be flush or slightly proud. To correct this, I used several lengths of 0.6mm diameter styrene rod and liquid glue to fill in the recessed trenches. The rod was carefully shaved down and then the weld pattern added by first applying some liquid glue to soften it and the scoring it with the tip of a round needle file.
With that taken care of, I moved on to Step 9 which adds the left and right fenders. Before committing to glue, I dry-fit the fenders along with the upper hull to make sure everything lined up correctly. I recommend actually gluing the upper hull in place first and then adding the fenders after to avoid drooping. The contact surface isn't that large with the lower hull and being "trapped" with the upper hull will make it easier to avoid this. I installed everything per the instructions order though just to see how it would work out.
The upper hull was quickly added in Step 10 along with the fender braces provided as PE items. The kit contains an error here in that the braces provided don't match the correct layout direction for both sides. The kit does have the braces staggered correctly as on the actual vehicle but the left side bracket tabs should all face forward while the right side brackets should all face rearward. Due to the way that Trumpeter created the PE pieces, this isn't possible. I achieved the next best thing by mixing and matching between the two different sides. The biggest area of concern are the middle brackets as their placement is crucial to avoid problems with the circular bulge in the upper hull for the turret ring. Since the rearmost brackets needed to attach to the hull, I left them off until the air vents were added in Step 11. The PE brackets are also just a touch too short vs. the molded in styrene mount points, resulting in a 1 mm gap when they are butted up against the hull as they should be.
This step also adds the front headlights and siren as well as the rear reflectors for the mud flaps. The square tabs on the front half of the head lights needed to be sanded down to match up with the backs as did the square tabs that insert into the fenders. Ditto for the reflectors, this is something that as I progressed through the build I noticed happening with consistency, the locator pins/tabs often aren't a good match for their corresponding installation points and require sanding or trimming to fit depending. The rear of the headlights and siren also had very prominent sink marks that needed to be puttied and sanded. I'll add the missing wiring later on prior to painting, I want to do that towards the end for handling reasons.
Moving on to Step 11 (which strangely isn't marked as a Step on the instructions but is there between Step 10 and 12), this focused on the rear hull details. The two vents were added along with their PE screens. The fit of the vents to the rear hull is good at the top but there's a slight gap that results on the inner sides that required some putty work to fill. The rear Notek light is also added here but judging by the reference photos, the kit designed mount point is wrong. It has the light mounting behind the angle fender bracket when in fact it should be integrated into it. No doubt this is a result of the choice to have PE bracket supports but it's another added inaccuracy on the detail level to this kit.
The step also adds the smoke grenade box and armored cover. The armored cover is provided as a PE piece with no option for styrene parts and it's a complicated endeavor to get it mounted. The piece is provided as a straight piece of brass with no bend lines etched into it yet it requires several 90 degree bends to form it into the proper shape. I eventually got it formed into the required shape but it took a lot of work to accomplish it.
Another element added in this step is the jack for the right side fender. The parts called out for in the instruction sheet are confusing as they all carry an N sprue designation but the numbers don't match to the parts on the N sprue. To add to the confusion, a complete alternate set of parts is provided on the M sprue to build another style of jack. Going by the reference photos, the M sprue parts are the correct type of jack to install so I ran with it instead of the confusing N sprue. The "foot" of the jack that faces to the rear had a horrible sink mark in it that almost went completely through the part. Some very careful putty work and sanding was needed to fix this and make it presentable.
Step 12 adds quite a bit of gear to the fenders but I left that off for now. The step also adds the two-part muffler and curved support brace/armored covering for the exhaust pipe. The two part muffler results in a prominent seam that I sanded down once the glue had set and the hollow exhaust point had to be carefully sanded/trimmed as it had some prominent flash to deal with. Mounting the muffler to the hull is a tricky step as it attaches only at one end via the curved support, part E47. E47 in turn attaches directly to the hull but its square mount tab was too big for the hole provided, requiring sanding to get it to fit properly. Once E47 had set, then the muffler was glued directly to it.
It's also worth noting at this point that the kit also leaves off the actual towing pintle for the lower hull, the L-shaped pin is not provided for in any shape or form. The rear mud flaps also have square-shaped indentations that I presume are meant to take parts to represent the hinges for the flaps but no parts are provided in the kit to accomplish this.
Step 13 deals with adding more on-board tools to the fenders so was skipped for the time being and I moved on to Step 14 which begins work on the turret. This step deals with the base of the turret and has 4 sub-assembly steps that need to be done first. One step constructs the gunner's chair out of 3 parts, 2 for the seat and a third that is the mount point to the turret ring. This part, C25, is shown incorrectly installed in the sub-assembly step as being parallel to the seat when in fact it should be perpendicular. If you install it parallel (which I did at first), when it comes time to mount it to the ring it's of course facing the wrong way.
The second sub-assembly is the radio, a two-part affair, and the square tab on the rear half is molded too deep to achieve a flush mating surface and needed to be sanded down. The third sub-assembly constructs the auxiliary turret rotating crank out of 3 parts, two halves and the crank wheel. The two halves need their seam sanded down and the wheel has to be carefully trimmed of its sprue attachment points to avoid damaging the circular portion. The fourth and final sub-assembly is the main turret rotating crank and consists of 8 parts.
The rest of the step deals with adding these sub-assemblies to the lower half of the turret. It also adds several additional parts and details, most of which required their mount tabs to be sanded, trimmed, or altered in some fashion to install properly. Two parts, C14 and D11, have large square tabs that match up to cut-outs in the lower hull but the cut-outs are much larger than the actual tabs, requiring putty to fill the rest of the space. Part E38, the base of the rear turret that the radio installs into, needed both of its square tabs heavily sanded to produce a good fit. As mentioned before, the fit of locating tabs is a constant issue to be dealt with and I often felt like Goldilocks when dealing with them....very rarely were they ever just right in terms of fit or alignment.
Next up will be the upper turret details and the main gun assembly.
