Day 10 was tackled in two sessions, morning and evening with a break in between to take my mind of the bolt head detail. First I would like to address some donor parts that are pictured on Real Models instructions but not called out. The rear fuel tanks parts C22 &23, Parts C25, 27 & 29 (air intake covers) as well as parts B26 & 28 (driver’s night vision viewer) and parts B24 & F17 that make up the gas caps. Photo etch parts 46 and 49 should have a tab on them that attaches to the top of the hull, these tabs can be seen in the color photo showing the left hand bustle rack.
I then decided to start adding the photo etch to the hull detailing it with some bolt heads. Figure 1 shows the left front of the vehicle with some photo etch and bolt head detail in place.
Figure 1 Left Front
Figure 2 shows the additional bolt head detail added to the photo etch on the left front.
Figure 2 Left Front Bolt Head Detail
The following figures shows the various photo etch brackets being installed along with the additional bolt head detail.
Figure 3
Figure 4
Figure 5
Day 11 started with me thinking about assembling the turret bustle rack assembly. Doing some preliminary research shows that photo etch parts 109 should be L shaped and not flat. I will be replacing these parts with some evergreen styrene. Also there are no real instructions that really tell you how to attach the bustle rack to the turret. I have the luxury of looking at a real vehicle, but if you look at the last page of the instructions you will see that the attachment points are bolts through a flat piece of metal to a mounting boss on the turret. This will also be replicated with some evergreen styrene. I had been warned that the assembly of the bustle rack would be a real challenge. This warning included some advice that resin part 15 was too small figure 6. Figure 6 shows what would happen if you bent the lower support frame to fit the mesh.
Figure 6
To alleviate this issue I used photo etch part 83 and made a template that I then used to shape the lower frame, figure 7.
Figure 7
I then bent the lower frame to fit the template created in figure 7 and attached photo etch part 83 to the lower frame, figure 8.
Figure 8
I decided to take a break from the basket and moved onto detailing the turret. My turret and a mold error on the commander’s side by the feed eject shoot. The right panel of the turret was deformed and filled a gap, figure 9. I also decided to replace the molded on washer and bolt head detail, figure 9.
Figure 9
Figure 10 shows how the LAVIII looks at the moment.
Figure 10
You can also visit my blog at
Canadian LAVIII Blog Tanks
Andy
