Not the recent Miniart kit but the earlier Techmod offering, this copy of mine was a Toga re-boxing of it.
These things always seem to happen to me. By the time I had bought the kit and rustled up some aftermarket accessories, the vastly superior Miniart kit was released, rendering other kits obsolete overnight.
Because of the dimensional issues and other inaccuracies, and a superior kit being available, I decided to build this as a fun project, adding AM parts, making some new ones where needed (as some detail parts are crude in the kit), without stressing too much over the inaccuracies present.
During this summer I've been making some progress every now and then between my other projects. To make it a little liverier, I'm planning on adding a crew figure having a smoke, from Tristar's tank crew set.
But on to the build. This is what I've been working on this summer:
Individual link replacement tracks, also by Techmod, removed from their sprues but not yet cleaned up.
The tracks were among the first items that I felt needed replacing. While the kit has link & lenght style tracks, they're somewhat crude and getting a characteristic Russian sag on them would be all but impossible and I've heard they're also tricky to install as well.
This set was affordable, offered much better detailed track links, came with better looking drive sprockets as well as several short plastic assembly jigs, altough I'll probably use something else while gluing them together.
Here's the main turret components:
Another part that needed replacing was the 45mm main gun barrel. While the kit part wasn't the worst I've seen, an aluminium barrel by Elefant offers a major improvement.
I added casting numbers to the gun mantlet using numbers sliced from left-over sprues and gave the part a rough surface with mr. surfacer 500.
Dimensionally, the turret is probably the worst aspect of the kit, being much too small and having quite inaccurate shapes and angles, but I'll be just adding detail and finally paint. The first details I added were the weld seams, which I made using stretched sprue, liquid cement and a hobby knife.
Here I'm test fitting the major hull components:
While the Miniart kit has a conventional hull "tub" and a few parts for the upper hull, this one has an old-skool "flat" hull made from several components.
Fit was surprisingly good, although warpage in the bottom part required some TLC and wooden beams to help keep it straight.
Sink marks are also present, requiring putty and sanding.
Some more dryfitting here, at a little later stage. The hull tub is glued together now and the fit of the rest of the components is checked.
The driver's hatch had some major sink marks, but fortunately there's no detail to watch out for while slapping on putty and later sanding.
And to close this first post, here's the crew member that'll accompany the finished vehicle, head and arms temporarily attached at this point
I'll probably keep the head and arms separate until final assembly to ease painting.
Until next time.
