Since I got a decent response to my query about posting a build log for my M103A2 build, I thought I'd take a moment to show you what was in store for you. I'll be building Commander's M103A2 (they called it a "Marine M103"). The biggest claim to fame this beast had was that it sported a diesel engine and had an M60-style engine deck. The kit itself is pretty crude and uses parts that aren't quite right. I'm going to do what I can, but since this is a solid resin kit, there is only so much you can do before you give up and walk away. One of the biggest issues is that the kit hull and turret are based on Tamiya's M48A3. This will make cross-kitting much easier, but the M48 contours aren't right for the M103. I'm going to live with it and not re-carve the hull and turret.
So, here are the players:
1. Commander's M103A2 kit. As you can see from the above photo, the one I got was damaged and I needed to fix the front fender with sheet styrene. In photo below, you can see more of the kit parts. The included PE sheet is about a mile thick and will need special handling. But, I'm going to use as much of it as I can in place of the crude resin detail parts. In addition, the kit includes a set of AFV club M48/60 chevron tracks. With some luck, there will be enough links in the box to complete the suspension properly.
2. Tamiya's M48A3 kit. Actually, I'm planning on using 2 of these for suspension and detail parts. I got them cheap, so hacking them up like this isn't too much of a problem.
3. Last, but certainly not least is an Italeri M47 kit. This will provide me with some of the finer details (namely stowage bin latch handles). I've got a left-over kit with plenty of bits and pieces and this should round out everything I need.
All for Now,
Georg
