Slow few days on the modelling front. I have the front bulk head and engine cleaned up and test fitted. Some Milliput to add to the seats and the Engine Cover Buttons and handles to fit.
These are quite small but fortunately you get a few extras incase the carpet monster gets some.
On the underside of the engine deck I filed the sides of the runners a little to get a better fit as it was a bit tight on the runners on the hull floor, same detail on the floor runners took a litle of each side.
The engine has a plug that needs sawed off and sanded down a bit and the front bulk head came off the mould plug with the aid of a sharp knife. No major issues, engine length is good and all should fit well together.
You need 8 eight buttons and handles and there are more than enough in the kit. I'm taking it this is standard in the sets as I had the same amount in the Mk I set.
Al
