Carty,
Just emailed you all the photos I used on my project.
The air filter on the aust M577A1 is the same as mounted on the cargo hatch of the M113A1. As for placement, I really had to guestimate the placement as it is normally hidden below a bunch of stowage. Here is an in progress photo of mine. Sorry for the poor quality I was not any good at using my camera at that stage.
You said you were doing a vehicle from 95 onwards:
• Well by that stage the vehicles had the indicators front and back. They were added just after Vietnam. The new ‘truck’ style indicators were not added until ~2000 and onwards. They were slowly rolled out to the fleet so it’s not unusual to see the old style indicators even up to 2006 and 2007. Some vehicles even have a mix of old and new indicator fitted.
• Note the placement of rear indicators on the M577 is different from an APC. The references I sent you should help
• You can probably use the old track – standard in most M113 kits – up until 2000ish
• You should add the sponson armour metal plates on the underside of the sponson from the 1st to the 3rd road wheel (only visible if you don’t put track shrouds on).
• Note aust vehicles have a locking mechanism inside the drivers hatch. Pictured above.
• And you would probably want to mount a .30cal MG on anything before 2001 ish. The pintle mount was very basic.
ACV’s tend to get modified a fair bit by their crews so you can generally get away with allot. That’s about all I can think of. Best of luck.
W
