I started detailing and assembling the dozer blade. A sad kit for the $$. If it was ½ the cost it would be worth it. It would be at least nice if they cast the parts a bit cleaner. All the grey you see in the photos is taymia putty used to fill in the imperfections (some pretty major). I also had to shim and cut the left arm a bit so the thing will be square and level. But that is what modeling is all about right?
Here is the rebuilt bracket. I carved away the blob, and rebuilt this using sheet plastic and a bit of wire.
As I started looking into adding missing details, I noticed that the plates on either side of the elevation cylinder housing are actually the end mounts for a large bar hinge that passes through the large triangle mount behind the blade. Understandable that the bar isnt included (they could have at least provided holes to put the bar through), but the plates are not even lined up with the hinge! So I used a chisel blade to cut them off and filled in the resulting gouges where I dug too deep.
Happy accident though…digging a bit deeper allowed me to reuse the plates. I sanded them down a bit, and repositioned them. Some brass rod carefully measured and bent made the hinge bar (in 3 parts due to the lack of holes in the hinge, and no way to get a drill in there to make holes). While at it, I made some lifting loops from copper wire, and glued on a data plate from plastic sheet.
Well now I have to tackle the alignment of the elevation cylinder to the mounts on the hull front….should be fun!
I’ve also started adding photo-etch parts to the hull, but pics on that later.
Have a good Monday!
Andy
