To finish up the turret assembly (6 total steps in the directions) I needed to complete the armor glass. Since AFV give you a nice set of clear armor glass, I tried an experiment to add depth when looking at the armor glass. First I masked all the glass areas. (I know the blue tape and blue background are not the best contrast)
Then I painted with successive coats of Alclad Gold, then Tamiya Flat Black and then Tamiya NATO Green. After removing the masking, here was what it looked like
Next I painted some clear decal paper with Tamiya Clear Green and also a mix of Tamiya Clear Blue and Red to make the Clear Magenta. Then I spent time with the digital caliper measuring and cutting and then mounting. To finish the turret I mounted the TC hatch, gunners hatch and sight, miscellaneous handles and the gun travel lock….which was a true PIA.
Without going on a rant, there are some parts which are so small on this kit, and there is no reason not to have molded them on the main assembly. Some of these appear to be parts for parts count sake. The side pars on the TC armor glass is an example. Others could make life better if done different. The travel lock is one of them. It is the one major drawback of the kit and does use up a lot of time to work with them correctly.
Back on the build, you see the assembled and base coated turret and drivers hatch.
Moving back to the main vehicle, the tires were nice and shiny rubber. To get them more the “used” look, I rubbed them down with a Scotch-Brite pad and then assembled them onto the rims.
With the tires assembled, I glued them in place on the chassis. Also I assembled the PE screens onto the vents, mounted the front guards, drilled the antenna mounts for an antenna, mounted the antenna mounts and the last few grab handles. After a final basecoat of Tamiya NATO green here is where I am.
Close up view of the PE screens. These went on pretty easy but do require care.
Close up of the tire assembly. The drive side front is the only tire with the ring. The directions incorrectly tell you to put it on both sides.
That’s it for now. I am working on the front and rear lights, mounting the drivers hatch, tow hooks, pioneer tools, some detail painting on the chassis and remaining PE straps for the chassis. Hopefully I will finish up the chassis this week leaving just the gun section to finish.
All comments are welcome, thanks for looking.
Rounds Complete!!
