To complement the review for this new kit by Vajra Miniatures, I will do a blow by blow of the building progress. As the instructions are typical for the genre (not very good..), it will be much of a trail and error story.
After examining the individual parts and some tentative dry fitting, we first need a plan of attack to determine the order in which we are going to work. The initial dry fitting indicated that some remedial force would be needed to get the four main components for the hull to fit correctly. I therefore decided to complete the hull before moving to the suspension, and to add the various hull and roof fittings to finish.
A very small twist in the lower hull was quickly resolved by holding the part over a boiling kettle, and gently twisting the rear to it's appropriate position. Cleaning up the considerable pour plugs is a bit of a chore, but the softish resin is easily worked with both razor saw and exacto knife.
Starting at the front, the front upper hull is easy to line up correctly, as the corner under the air outlet (circled) should fit flush to the lower hull. There is an accuracy issue here, but more about that later. Right now, we want to fit the hull components. Note where the angle of the upper hull meets the lower hull (arrowed), this should be flush. If it is stepped, you are too far back. In my kit this results in the front of the upper hull sticking out over the front of the lower hull by a milimeter or two (circled 2). Again, this is part of an accuracy problem which I will come to later.
When the parts are lined up correctly, apply a fairly generous amount of CA, and repeat the process on the other side. The photo shows the rear section in place, but don't worry about that right now. You need to check that the point circled 1 and 2 line up correctly. The 'gap' you can see between the upper and lower hull is intentional, and should actually be a little bit bigger. The section of the lower hull that connects to the upper hull is in reality a separate part, that is fitted a few centimetres proud of the hull. The model tries to replicate this with a simplified one piece casting, which is not entirely successful. This is part of the problem with the front, which I will explain when I attach the nose section.
Next step is the rear section of the hull. On the real vehicle this section is a removable module, which can be interchanged to optimise the vehicle for a specific operation. The kit stays true to this concept, in that the rear section is separate and has a separate floor section, but it is not removable as such.
First we position the floor section. I removed the locating pins, as they did not line up exactly, and they are not really needed any way. Do not glue at this point...
Next the upper hull section is positioned so as to line up correctly at the rear of the vehicle. As this part of the construction gets a bit involved, I'll tackle it tomorrow.
Henk
