Step.G.11.2. Gun barrel is put in place along with two parts on the left wall of chassis.
1009 parts used.
Step.G.12.1. In this step several subassemblies of parts that will be placed on the chassis is done. Except for problems with cutting out F18 part (handle of shell support) which is extremely thin and is being hold on a tree with quite thick and multiple arms no assembly problems appeared.
Shell support should be assembled on arm without a glue (it should be able to rotate) but it was very loose. I used heated screwdriver to delicately flat the end of supports axis – now it stays in place and is still able to rotate though it’s quite delicate.
15 parts used for these subassemblies.
Step.G.12.2. Placing subassemblies on the chassis along with few other parts on the wall and control panel.
1034 parts used so far.
Step.G.13.1. Ladders and platform. Ladders can be made in two ways – full length or folded. The folded version is required if you build a gun on a cross track, but can be also used for straight track. I’ve built both ladders in full length option. Some delicate filing and sanding was necessary with side ladder parts.
Platform is made of five plastic parts and a mesh. I must say that mesh is kept in scale (it is plastic) and is quite firm so there is no problem with attaching it to a frame.
20 parts are used for these subassemblies (including mesh as 1 part).
Step.G.13.2. Assembly of ladders and platform on main chassis. I had to adjust the ladders a little to make them fit to the walls and the deck, but it was a delicate adjustment and took only about 5 minutes.
Platform is attached in two points – no problem here. Only difficulty is to keep it horizontal (there is almost no horizontal lines on the chassis near the platform – no reference level than…).
Four additional parts are being used in this step to attach ladders to a wall, there are four other parts placed on the walls in this step as well.
1062 parts used by now.
Step.G.14. Hand rails assembly. There are four of them placed on main chassis. These sure are parts with highest length to thickness ratio in this kit
There is a cover of control panel attached over it in this step as well.
1067 parts used so far.
We have the gun, trucks and ammunition wagon done already so next step is final assembly.
Andrzej
