Hi James,
She's looking great! I've been meaning to comment since, oh, about the 14th
Okay, now that the salutations are out the way, time for 101 questions
1) I noticed that some ammo rounds are in the stowage tubes, others out - is there any regulation or rule as to how the ammo should be stored? Would I be wrong to depict them all being in the tubes, or all out, or half and half?
2) I note that you've painted the floor (specifically the escape hatches behind the driver) OD - so is it only the interior sides of the hull that are white?
3) What thickness brass wire did you use for handles on the rear hull?
4) What's this 'sponge technique' you refer to?
5) I understand that the outside of US tanks was baked or something, so the OD didn't chip so much (if at all) - is this not true to the interior as well? Were the interiors painted?
6) Nice work on the idler wheels - are you only closing in the one side of each wheel?
7) Road wheels - are you planning to chip the "rubber" at all?
Phew
Not quite 101, but I think that's all
TIA mate
Rudi
(p.s. mine hasn't progressed much since the last update - been having fun with the PE exhaust deflector boxes - now there was some interesting contortionist bending
Hi Rudi,
No worries about the interigation, i'll do my best to answer all your queries;
1) As I understand it, rounds were supposed to be stored in packing cases, presumably to reduce the risk of them getting thumped/hit by shrapnel etc. and acidentally going off. Therefore, I have shown most of mine stowed this way, however, I also beleive the crew would have a few rounds 'ready to go' especially as my build is portrayed as a front line AFV that will have come up against enemy armour. It also adds a little variety!
2) This colour scheme is based on other builds and common sense, not actual reference material (tut tut I know but I couldn't find any). The OD is harder wearing and more available to re-paint the floor, and also from above it aids the camouflage of the vehicle. You can copy this, go for all white, or even all OD for this rear part, but I figure this is the most logical combination. Incidentally, the escape hatch is behind the co-driver I beleive, so the area behind the driver is either stowage or access to the drive shaft im guessing?
3) 45mm wire.
4) You basically cut off a bit of kitchen sponge and dab it in the desired colour paint, then dab it on paper to remove excess (like with dry brushing) and then dab it onto the desired area of your build, hey presto random thin chipping, but practice first!
5) Yes, OD was pretty 'chip proof' but I can't comment for the interior, as it wouldn't matter as much it may not have been and simply been painted with regular white paint, hence my chipping. I don't know for sure though so I stand open to correction. I think it makes for a more 'used' looking interior though.
6) Thanks but not sure what you mean here. If you look at reference pics or museum vehicles with this field mod done, you'll see that they had one set of plates welded on the inside of the wheel. Edurad do seem to provide extras and i'm not sure why. Plates whould only be on the inside of the wheel though.
7) I have already been over them with a mini motor tool and a round burr, but I didn't go to overboard, this is often overdone I feel as people use museum AFV's for reference where the rubber has had 50 years to perish. I feel just enough to make them look used is enough depending on the build.
Phew! And I just answered your PM questions too!
Hope that all helps you mate, i've got an update on the way. Good luck with those screens, I found mine went together easily enough, there just wasn't enough surface to glue the final peice of mesh onto easily.
Cheersm
James
