It looks great, especially for a first dio.
Just a few words of advice...
-The one guy looking at the map on the well with glasses probably wouldn't be wearing a bright red shirt. It would more likely be feldgrau?
- Your camouflage on the figures looks good. Try to create some variety by using different camo patterns on the figures You can use a re-enactor's equipment site
like this one to see what the patterns were like.
- Your decals are silvered! Don't worry, this happens to everyone...or maybe just me. I use this method slightly modified from... someone on the site, sorry, I can;t remember who.
Items Needed:
1. Future (over coat, either airbrushed or brush painted on)
2. Elmers Glue
3. Micro Set (I use vinegar)
4. Water
Process:
After Future has dried for a few hours...a day to be sure.
1. Mix the Elmer’s' glue with water and a small amount of Micro Set...you want the consistency of saliva...take this mixture and paint it onto the decal location.
2. Wet your decal (I wet it in the vinegar) and allow it to soak and separate from the backer in the palm of your hand.
3. Using a brush, coax the decal off the backer and onto the puddle of Elmer’s/ water/ Micro set.
4. Use the brush to position the decal to the exact spot needed.
5. Let the decal sit for a few minutes, then use the brush or a q-tip to flatten the decal out and push out any bubbles, etc that can be seen
6. Lightly paint on some Micro Set on to the now flattened decal.
7. Monitor and let dry....after a few hours you can come back and re-wet the surrounding white glue puddle and remove.
8. Over coat with future, and you’re done with very slim chance of any silvering.
This metod works perfectly as long as you don't do it over zimmerit! For that...I have no idea!
I'm just trying to help, please don't take this too harshly
SCOTT
