Baaaackkk to the original question...
I use enamels and acrylics. I like acrylics (primarily ModelMaster) for airbrushing, because they clean up easily and don't foul the air. The odor from sprayed acrylics is almost nil (there is a bit of alchohol smell, but not bad), and since I have no spray booth it helps keep my wife off of my back. I use the ModelMaster airbrushing thinner that they recommend, but usually not much of it. With enamels, there is odor from the solvent when spraying, and also when cleaning up. There is a residual odor from the waste you dispose of, unless you take it out right away, too. So, acrylics for spraying.
That said, I prefer enamels (again, mostly ModelMaster...can't beat the color selection!) for brush and detail painting. I have not been happy with the coverage I get from acrylics when I brush them, and the enamels seem to do a better job off of a brush. Other than some of the paints (Ral Partha, etc.) made for fantasy figs, I have had significant problems with acrylics on figures. The thinner consistency of the acrylic seems to want to settle into depressions, leaving poor coverage on the high spots. This is just my opinion of course, others may have different experiences.
I rarely use the Testors enamels that come in the square bottles. Something about them just doesn't work for me. They seem thick or heavy or something.
For washes, use enamels. Acrylics seem to go all grainy and don't flow well when thinned that far. They also don't stick that well, I have had the pigment come off on my fingers days after the wash was put on.
Good luck!
Acrylic or Enamel
ARENGCA
KitMaker: 382 posts
Armorama: 267 posts
Posted: Monday, April 29, 2002 - 12:26 AM UTC
YodaMan
KitMaker: 1,561 posts
Posted: Monday, April 29, 2002 - 12:32 AM UTC
Yes, that sure is true! Most of the paint also seems very sticky. I don't remember if that was mainly for the gloss enamels, but I now buy only the ModelMasters acrylics and enamels. Most though, I stick to the acrylics.
YodaMan
A compressor, I now own. (quiet it is)
m1garand
KitMaker: 1,248 posts
Posted: Monday, April 29, 2002 - 12:33 AM UTC
That and the color doesn't always seem right to me. I use Model Master and Humbrol enamels.
GO SHARKS!!!
Tiger1
KitMaker: 171 posts
Posted: Monday, April 29, 2002 - 12:35 AM UTC
I prefer acrylic's over enamels. I use acrylic's almost exclusively when I paint German Armor (which is the majority). But I will use Humbrol enamel's when I paint Allied Armor. I always make sure that I use my spray booth and respirator when using enamels. Also I like to wash my AFV's in oil's, so base coating with acrylic's is a safer option. :-)
210cav
KitMaker: 6,149 posts
Armorama: 4,573 posts
Posted: Monday, April 29, 2002 - 01:32 AM UTC
One more month until the birthday present is mine...a new airbrush and a compressor. Until then, I am adjusting to using Master Modeler spray cans and trying to use the bottled air brush....a true challenge. I might add it is also a wee bit expensive. Those darn bottle run $12 a piece.
DJ
DJ
m1garand
Posted: Monday, April 29, 2002 - 01:36 AM UTC
DJ![]()
The only spraying I do right now is Model Master spray cans, they work, but not many effects and not much control.
YodaMan
Posted: Monday, April 29, 2002 - 01:39 AM UTC
That's exactly why, 2 months ago, I said I would not paint a model until I got my airbrush!
YodaMan
Go airbrush, GO!
YodaMan
Go airbrush, GO!
m1garand
Posted: Monday, April 29, 2002 - 01:41 AM UTC
YodaMan
Go airbrush, GO!
But then all you have are naked models. :-)
YodaMan
Posted: Monday, April 29, 2002 - 03:10 AM UTC
Riiiiiight..........
210, if you're looking for something else to thin acrylics, Testors has something called
'Acryl Thinner
Dilutant Acryl' (the number is # 50496)
"Use for thinning Model Master Acryl paint"
I don't know too much about it, but I got some so I'll try it and tell you how it works.
YodaMan
'Acryl Thinner
YodaMan
m60a3
KitMaker: 778 posts
Armorama: 396 posts
Posted: Monday, April 29, 2002 - 03:18 AM UTC
Acrylics for tanks and airplanes(Polly S/PollyScale/ModeltMaster), washes in either enamel or oils (or both). Have been using acrylics since my dad first got me into modelling (1971).
For figures, acrylic base (Vallejo/Andrea/Prince August), oils for painting, shading and highlighting.
Avs, Isles and Habs BETTER finish the job...Ted Nolan to the Devils!
210cav
Posted: Monday, April 29, 2002 - 03:54 AM UTC
'Acryl Thinner
YodaMan
Yoda--many thanks. I shall purchase some in the near future.
DJ
pipesmoker
KitMaker: 649 posts
Armorama: 379 posts
Posted: Monday, April 29, 2002 - 04:54 AM UTC
I prefer enamels for my base coat, then acrylics over for final coat.
Enamels first because I usually forget to wash the parts before beginning to build.
I use Model Master or the little Testors bottles and then Tamiya, MM or Badger acrylics.
RufusLeeking
KitMaker: 330 posts
Posted: Monday, April 29, 2002 - 05:00 AM UTC
Like the other Ron, this Ron also uses both paints, but I prefer enamels. The family hates it when I shoot enamels...maybe that's why I prefer them.
Phantom
KitMaker: 195 posts
Posted: Monday, April 29, 2002 - 05:59 AM UTC
I switched almost entirely to acrylics about ten years ago. I still use enamel spraypaints, but only use a couple of enamel jars. I'm convinced that all those years of enamel and thinner fumes have killed a considerable portion of brain cells over the years.
I've never tried oils - they always seemed difficult to work with, and slow drying time hasn't always worked well with my building style. :-)
penpen
KitMaker: 1,757 posts
Armorama: 929 posts
Posted: Monday, April 29, 2002 - 06:11 AM UTC
I use mainly humbrol enamels.
I've just baught some artist oils and I'll be trying them on figures within a few days.
When doing a wash with acrilics, to make sure you don't get that grainy look, add some dishwashing soap ! It works great.
penpen
penpen
matt
KitMaker: 5,957 posts
Armorama: 2,956 posts
Posted: Monday, April 29, 2002 - 06:12 AM UTC
I use both (mainly enamel because that's what i have the most of) untill it's gone.
Matt
Matt
TreadHead
KitMaker: 5,000 posts
Armorama: 2,868 posts
Posted: Monday, April 29, 2002 - 10:22 AM UTC
Quoted TextIt'd be a downright shame if the Avs lost to the Kings tonight in game 7......Tread.
GO AV'S !!!! CRUSH ALL WHO COME BEFORE YOU!
ESPECIALLY THE 'WINGS'. EAT THEM FOR LUNCH, WITH A SIDE OF RANCH DRESSING & CARROT STICKS...
HA HAAAAAAAA!!!![]()
YodaMan
GO RED WINGS!!! GO GO GO!!!
THE AVS WILL BE BURIED!!!... FORGOTTEN IN THE FIRST ROUND! HA HA HAAAAAAA!!!!!!
...................you can be dealt with......I got a couple of 'Goomba's' in Detroit that can........
I better shut my mouth until the end of the Game...
Tread
Tin_Can
KitMaker: 1,560 posts
Posted: Monday, April 29, 2002 - 10:31 AM UTC
Long time ago I used the old testors enamels. Since returing to the hobby I discovered acrylics and now use Tamiya Acrylics exclusively. Their easy to clean up and are great for airbrushing. Believe it or not, I've actually airbrushed the tamiya acrylics straight from the bottle. Normally when airbrushing, though, I thin with reagular alcohol at a 1:1 ratio for general coverage work. One thing I've found out with the tamiya flat acrylics is that when thinned with alcohol and airbrushed they come out very, very flat which is nice. For airbrushing weathering or detail work I mix a very, very thin mixture of paint-about 1 drop to 2 or 3 eyedroppers of alcohol. I normally airbrush from 15-20 pounds but have gone higher for certain applications.
TreadHead
Posted: Monday, April 29, 2002 - 12:30 PM UTC
YodaMan
O.K. Yoda Man.........I just gotta say it................
GOOOOOOOOO AVVVVVVVVVVVVVVVVVVVVV's!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
YEAH!!!!!!!!!!!!! Won game 7!!! Not only won it, but SKUNKED EM!!!!
HA HA HA HA HAAAAAAAAAAAAAAAAAAAAAAAAAAAA!
........humbly ,
Tread.
............hehehehe.
210cav
Posted: Monday, April 29, 2002 - 08:00 PM UTC
Bryan--thanks for the info.
DJ
Bravo-Comm
KitMaker: 525 posts
Posted: Tuesday, April 30, 2002 - 02:04 AM UTC
DAGGER: A weapon with a short pointed Blade: "THE CUTTING EDGE"
YodaMan
Posted: Tuesday, April 30, 2002 - 02:28 AM UTC
Seems like those cans of compressed air can get expensive after a while too. I was at the hobbyshop yesterday, and they had a big can of compressed air for $13. That would add up after a little while...
YodaMan
My 5th consecutive correctly spelled post
YodaMan
Tin_Can
Posted: Tuesday, April 30, 2002 - 02:36 AM UTC
YodaMan
Put it this way Jedi Master,
For eight or nine of those cans you can get a pretty descent compressor in the CH FP2003.
210cav
Posted: Tuesday, April 30, 2002 - 02:49 AM UTC
Bryan--I pray to the great gods of modeling to allow me to put $12 down get the blasted can of air, finish the model, and await the speedy arrival of the birthday compressor and airbrush(es)....
DJ
DJ
YodaMan
Posted: Tuesday, April 30, 2002 - 02:57 AM UTC
I just went out and got a job. (my parents were getting tired of me begging them for a compressor) Bryan--I pray to the great gods of modeling to allow me to put $12 down get the blasted can of air, finish the model, and await the speedy arrival of the birthday compressor and airbrush(es)....![]()
DJ
That way, I can afford a compressor a week. If I wanted to.
YodaMan
