Hi,
I've finally managed to get some pictures taken of the model.
It took alot longer than I planned to remove all the stubborn casting blocks that come with the Legend kits.
Here are some of the hull applique armour parts civered in Maskol prior to adding the Rustoleum spray which replicates the anti-slip coating.
Once sprayed they have now been mounted on the hull of the Bradley
Even though the ERA will be mounted on the hull front I still want to portray the anti-slip coating underneath.
Here the ERA blocks have been masked and sprayed with Rustoleum.
The turret vision blocks were removed and placed on 40 thou card so that when the additional armour was added the commander could still see through them. The commanders turret has also had the roof covered in Rustoleum.
A fair bit of work was completed on the side armour plates. Firstly the sink holes were filled and sanded smooth, then an additional piece of 40 thou card was added at the front of the left side plate. Additional holes were made as the Tamiya part is incorrect at the front. I then added the strips that run alomost the whole way down each plate and added bolt detail. I also added the larger bolt detail on the reverse side of the plates.
The ERA armour has been added on one side. It needs some filler as it was slightly warped and I couldn't get it to go straight.
All comments welcome. I will post some additional updates when I can!!
Toby
