Well i seem to have taken a much longer break than i had intended, but i think i'm at a stage now where i'll be able to go a while longer at this without taking another huge break. A lot has happened since i last posted though. Sadly, the building had to go- it was just too out of scale and unconvincing. This seemed like the perfect opportunity to try out one of miniarts vacuum formed building kits, and if this sounds like an easy option, believe me, it isn't
I will try to salvage the lamp and electricity box, although the water pipe is too out of scale to be used.
After following the tutorial on the miniart website, i've now got the building (35519 Ruined city building) built and most areas filled so that the join cannot be seen. I've also nearly assembled the figures from the tamiya russian army assualt infantry, which will need a bit of work to get them up to scratch. Some of them are in the pics below, there are 12 in total, although i will probably leave one out. Note that apart from the ones mentioned, the positions of the figures will not be as shown, this is just so that you can see some of them.
This figure will be one of 3 or 4 figures riding the tank.
This figure will be lying down behind some low cover such as a barrel.
This figure will be positioned roughly in the same place in relation to the building, so that he is using the wall as cover.
At the moment i am working on the detail for the building which consists mostly of the the windows. I am using the kit parts, but will be altering them to show extensive blast damage to the glass and frames. No glass is provided with the kit, so i am using clear 0.5 mm PET, which glues quite well with thin poly cement without melting. Here is the first completed frame.
