M1A2 SEP Dio Project
Removed by original poster on 08/18/09 - 22:13:36 (GMT).
majjanelson
KitMaker: 1,355 posts
Armorama: 979 posts
Posted: Monday, August 03, 2009 - 05:01 AM UTC
Alldredge,
From your picture, it appears that your hull is higher in the front that at the back, but the hull isn't completely installed, since the engine/Fuel tank deck has a gap with the rear sponsons (top part of the rear hull). There seems to be a little more of the top of the road wheel covered on #5 than there is on #2. Not much, though.
A couple pictures from Prime Portal of a similar angle for the bottom of the side skirts vs. the road wheels.
The Abrams loaded on the HETT trailer could be depressed slightly, but I don't think you will "lower" a 70 ton tank's suspension very much with mere chains!
Hope this helps you...
Removed by original poster on 08/18/09 - 16:14:09 (GMT).
Removed by original poster on 08/18/09 - 16:16:43 (GMT).
