Dang John Jaw dropping good.
Most would not really believe the size of the thing.
This is Frigging fantastic.
The detail is beyond belief.
Great job from rags to riches.
Hope to see more of your builds and keep making some parts.
Any hope on you switching to German stuff soon?
Decals, PE for Flak guns and Kubblewagens ,Jeeps.
One question what color did you use on that antenna base looks dead on a match for the ceramic ones?
Thanks for the compliments everyone they are much appreciated,
Jeff, for the insulator porcelain color I use Tamiya Hull Red. After the Paint dries I apply gloss clear lacquer to get the luster. I also do this Procedure on my 1/35th scale tanks. The antenna insulator adds a lot of color on American tanks, and it is commonly missed on a lot of 1/35th scale builds.
When it comes to Decals, I don't like to use decals in scales over 1/16. You will have the same issues with 1/6th scale decals that you have with 1/35th scale decals. These would be decal gloss, chips, rips...etc. For my markings I make my own stencils by creating them on my computer, printing them out on sticker paper, and cutting the markings out with an x-acto. I then stick the template to the tank and add the paint with an airbrush. The airbrush gives more precision and control on the paint intensity and brightness, which gives you a more realistic look. There are water slide decal sets in 1/6th scale. They are offered by a company called John's stuff, they can be found on the
Sixth Army Group .,
the tank is now finished. I will now be creating the tank's gallery webpage. Once the webpage is complete, and the shop gets a good cleaning I will then start on my next project(s)
I have added the last of the parts to the tank including the pioneer tools, and the fuel caps.
I have also added the last of the M3 parts to the product line.
http://www.eastcoastarmory.com/ustankparts.htmI have added the large suspension spanner wrench to the US AFV tool set.
The last parts that have been added are the resin Rivet heads. The heads come in two diameters the smaller 5/32nd which are used on the top deck, and the rear plate
and the larger 11/54th which are used for the tank's sides plates.
I took advantage of the good weather and I was able to get some pics of the M3 out doors.
I also made a rendition of a propaganda image that was taken in Fort Knox in 1940
