The USMC doesn't use A2s. They use all M1A1s. The Tamiya M1A1/A2 kit comes with the parts to build a USMC M1A1 from about 2003. If you want a more up to date one, you could get the Dragon M1A1 AIM and then source the USMC parts (double 4-stack smoke launchers at a minimum) to convert it into a USMC tank.
If you want to go all out with the details and pretty up to date, follow the below items.
USMC M1A1HC/AIM UpgradesChange out the smoke launchers to the USMC 8-shot, double-stacked type.
EPLRS antenna mount, thin post to the right side of regular antenna.
APU Power Junction box. New electrical conduit is the angle-iron piece running along the left side of the blow-out panel.
Power connection box next to the man-hole cover. There are two screw caps to connect to located on the front of the connector, toward the front of the tank.
PLGR antenna is mounted somewhere on the turret roof. It is usually in front of the crosswind sensor. I have also seen it to the front right of the TC's cupola as well. The location for it varies.
Tank/Infantry Phone and rear Slave Cable Receptacle on right rear of hull on latest AIM tanks. (Added in '07. Prior to this, they had just the T/I box on the right rear.)
Deep fording kit exhaust flange on HCs and AIMs.
The box in front of the loader's hatch is an MCD (Missile Countermeasure Device). It is used to defeat optically and laser guided anti-tank missiles.
Some USMC M1A1HCs are using the old sprocket retaining rings as well. They were found to be an easy fix to counter the track losing tension during operations. The USMC started putting the rings back on M1A1HCs in the early-mid nineties that were stationed stateside on the West Coast (1st Tank Bn) and they were seen on tanks on deployment with the MEUs until 2006. No rings are/were on the sprockets of East Coast (2nd Tank BN) tanks though. Most USMC tanks that came off of the Maritime Preposition Ships (MPS) in Kuwait for OIF I /II did not have the sprocket retaining rings other than at least three known tanks that came off the MPS ships with them. The USMC tanks that have been seen in Iraq with retaining rings are from stateside (1st Tank Bn). They are part of the different ocean-going Marine Expeditionary Units (MEU) that have gone to Iraq and participated in the festivities over the past few years. So, specific USMC tanks could be seen with the rings applied.
The below pic is a USMC M1A1HC in ops in Kuwait with the rings on it.
For the USMC BRE used in OIF.
Eduard makes one in PE, set # 35598. There is also one in the new(ish) Academy M1A1 Iraq 2003 kit. It is one of the few good pieces off the new J sprue. It also has a T/I Phone box on the new sprue. The rest of the kit sucks though. The Dragon M1A2 SEP kit comes with a nice PE and plastic one as well.
You can take a look at my
M1 Variants Article as well for more info and pics.
You can also take a look at my USMC M1A1HC that I did a while ago.
"Angry American", USMC M1A1HCThe Tamiya M1A1/A2 kit comes with the MCD and smoke launchers. The Academy kit also includes the T/I phone box, smoke launchers, BRE, and MCD as well. Echelon makes a couple great decal sheets for Marine Abrams in Iraq too. They also have another sheet coming out soon.
