Test fit of hull, side view. Note the molded attenna guards. Unfortunately Trumpeter box art really doesn't do their models justice as it tends to emphasize flaws.
Front view. Parts are loosely fit, but you can see the large gap on the front hull panel. It should be easy to remedy and thus far is the only poorly fitting part. All of the other panels fit very well.
Engine compartment installed. Again a loose fit so forgive the appears of one of the interior panels. It actually fits quite well. Hard to believe there is now way to view the detail without modifying the kit and removing the engine access panel. Not an easy thing to do. Ejector pin marks are prominent on some interior surfaces, but should be easily filled.
Another view on the engine compartment. This time I placed the piece connecting the engine to the transmission. In case you were wondering there is a prop rod molded to the inside of the engine access panel. Its not just a flat piece of plastic, but there is now way to remove it without destroying it. Maybe they want you to buy two kits for that instance?
Not the clearest photo I've taken, but a close-up of the mounting tabs for the fenders. As most M113s in Vietnam had the fenders removed, this is a "must fix". I clipped the tabs from the kit parts and used them to fill the voids. They were a snug fit and "T" shapped so it worked out pretty well. Still need a touch of filler and to trim away the slots in this photo, but you get the idea. As most Braille scale kits go, the suspension is molded to the hull. Hard to fix if you want to pose the suspension over rough terrain, but for a Braille scale diorama, who really gets under the vehicle to notice if you take a modelers liberty and just relocate the mounting lug on the arm.
Right now I plan to have the rear ramp closed, but all top hatches open.
