Superbe result Nige!
I like it very much.
I would have loved to see a bit smoother folds with the arm protections.That's the only negative.
Claude
Dioramas
Mine and booby trap training diorama
roudeleiw
KitMaker: 2,406 posts
Armorama: 2,224 posts
Posted: Thursday, June 24, 2010 - 06:44 PM UTC
Gorizont
KitMaker: 1,462 posts
Armorama: 1,289 posts
Posted: Thursday, June 24, 2010 - 08:48 PM UTC
Yes, great result!
But using sunlight as lightsource would give this scene a "better touch". (better color-reproduction)
It could look like these photos from 06. June.
For removing -too bright- parts in the photo, you can hold a sheet of white paper in direction of the sun. (blocking the light)
The result is a "smoother" brightness / contrast.
greetings...
Soeren
greetings...
Soeren
Tommygunn
KitMaker: 36 posts
Armorama: 28 posts
Posted: Thursday, June 24, 2010 - 08:54 PM UTC
As Claude indicated, would it not be possible to use foil or tissue paper instead of putty for the arm blackouts, to get a better reproduction of the fabric?
Tom.
Tom.
okdoky
KitMaker: 1,597 posts
Armorama: 806 posts
Posted: Friday, June 25, 2010 - 12:59 AM UTC
Tom.
Hi Tom and Claude
Tom the putty was on to get the general bulk and fixing into the holes around the arms ans was supposed to be masked and shaped by the fabric covering which is the thinnest of tissue dressed with very watered down PVA glue.
Claude is right that I found the holding and fixing of the arms in place very fiddily and as such lifted super glue cross contaminating on the the fabric making the folds look bad.
Now the arms fixed I will see if I can carve back the putty and tissue on so far, and re-dress with fresh tissue to see if it will look any better. This may be a little awkward with a couple of the arms as they are close or even crossed over each other.
The pics were taken inside my fume cupboard/spraybooth that has two powerfull lights each side so they lighting is very bright. Will take daylight shots outdoors when the dio gets closer to finish.
I am dreading the painting of the figures as this has already been third attempt so far.
Thanks for all the encouragement from all.
Nige
roadsidesbr
KitMaker: 11 posts
Armorama: 10 posts
Posted: Friday, June 25, 2010 - 05:10 AM UTC
very nice!!!
