Hi Rob,
I've used 30psi for some of the 'colours' although the grey/white is next to be sprayed on a future build. I am going to try the grey at 40psi.
As modellers we should avoid spraying at set PSI's as temperature & humidity can be contributing factors.
Regards
Brian
REVIEW
Vallejo Acrylic - Urethane white prPosted: Thursday, June 21, 2012 - 08:32 AM UTC
viper29_ca
KitMaker: 2,247 posts
Armorama: 1,138 posts
Posted: Thursday, June 21, 2012 - 03:06 PM UTC
I usually am using 25-30psi for the primers.
Spiderfrommars
KitMaker: 3,845 posts
Armorama: 3,543 posts
Posted: Thursday, June 21, 2012 - 07:54 PM UTC
So do I. A little higher than usual
cabasner
KitMaker: 1,083 posts
Armorama: 1,014 posts
Posted: Saturday, June 23, 2012 - 05:46 PM UTC
I JUST got the grey Vallejo primer, and used it for the first time. The first time i tried to spray it, I thinned it, which was a major mistake. I found that spraying this stuff works perfectly when using it straight out of the bottle. I found that about 20 pounds through my Iwata airbrush worked just fine. Cleanup was an issue at first, but I followed advice I got here on Armorama, and using SImple Green works great. Very nice stuff!
imatanker
KitMaker: 1,654 posts
Armorama: 1,565 posts
Posted: Sunday, June 24, 2012 - 12:48 AM UTC
Curt,glad it worked for you.Simple Green is good stuff.Jeff T.
GALILEO1
KitMaker: 1,794 posts
Armorama: 1,431 posts
Posted: Monday, June 25, 2012 - 07:36 AM UTC
Thanks for the input on your pressure settings gents. I'll be giving the primer a try in a few weeks when I get closer to the painting stage of my current project.
Rob
Rob
Militarymodeller80
KitMaker: 117 posts
Armorama: 90 posts
Posted: Tuesday, June 26, 2012 - 06:48 PM UTC
Hi
I spray the Vallejo primer at the same pressure as all other paints and that is around 15 to 18 psi.
CptSpitfire
KitMaker: 41 posts
Armorama: 12 posts
Posted: Wednesday, June 27, 2012 - 04:49 PM UTC
The nice thing about this stuff is you can pretty much throw it on by brush and it will self level really nicely.
SSGToms
KitMaker: 3,608 posts
Armorama: 3,092 posts
Posted: Wednesday, June 27, 2012 - 06:11 PM UTC
That's true, it brush paints as well as it airbrushes! I never mentioned that this gives the Vallejo Black, Grey, and White primers a huge advantage. If you have done sanding or putty work, or need to check a seam for gaps, you can primer just that one small area with a brush (which will show up the flaws) and fix it before it's too late.
