Thanks as for the tracks I disconnected the tracks which is why they look so saggy. As for the sag the tracks sag more when the tank is finished because of the extra weight of all of the components,
I have more progress on the model's engine deck. Most of the details have been added and the engine deck is about 98% complete.
I used the kit supplied grills for the model. The kit supplied grills are all made of CNCed aluminum. They are nicely machined but needed a few minor tweaks.
Fan Grills
Radiator Grills
For the fan grills cast texture and foundry marks and numbers were added
The radiator grills needed to have the one segment cut away from the rest of the grill. The stock grill does have the segment partially removed but not all the way.
Before
After
For the grill meshwork the kit does supply you with laser cut steel frames and metal mesh.
The Laser cut frames for the radiator grills were reworked to make them hold the mesh, but the kit doesn't supply you with 4 frames, only 2. So the other two frames were fabricated out of sheet steel by using the laser cut ones as a template.
For the fan grills the laser cut parts were not used because they were flat. From the images that I have of the grills and from the aberdeen jagdtiger the fan grills were made out of a round rod that the mesh would wrap around and would then be welded to the fan grill. To fabricate the mesh work I bent two brass rods into the same size circle as the grill, and soldered them together.
For the mesh I also didn't use the kit supplied material. I felt that the kit supplied mesh was too thick and would not only be too difficult to work with, but would also cover up the intake and fan detail that I built into the tank earlier. Instead I went with varmint mesh that I have used on my other 1/6th scale tank models.
The mesh and frames were first installed on all of the grills, then were all mounted onto the tank.
After the grill work was mounted to the tank focus was then shifted to the engine hatch.
The kit supplies you with the parts to assemble one basic detailed engine hatch. As with most of the tanks parts they are all constructed out of metal
The air intakes were returned on the lathe to further sand down any tool marks left from manufacturing
The hatch hinges were also reworked.
Stock hinge
reworked shape, before the hinges were mounted hinge stops and cast texture were added.
In addition to the hinges the lever mount, air intake discs, and resin hatch retaining latch were added.
The hatch locks and latch point were also added. The locks are functional, and these parts will soon be added to the product line.
After the hatch was completed I then focused on the rear deck access panels.
The stock components have the correct size and shape, but are missing the mounting bolt, the panel and mount is one piece missing the crease line separating the mount.
To rework the mounts the mounts were resanded on the lathe, cut the crease line into the mount, and I drilled and mounted the top mounting screw.
For the other air intake the kit supplied part was used as is.
The only additions that were made were a small screen mesh cap and resin bolt heads.
For the engine deck lift hooks I used the kit supplied laser cut steel hooks. The only mod that was made was the addition of a small hole drilled into the hook's bottom point
The fan plate hooks were not included in the kit and were scratch built out of sheet styrene. The antenna storage tube was another addition that was scratch built.
After I finished mounting the hatch I had the idea of mounting interior lighting. The purpose of the lights is that when I have to access the front or rear of the vehicle for maintenance or to recharge the batteries I can have light so I can see what I'm doing. The lights were easy to mount They consist of four white LEDs (two in the front and two in the rear). The lights turn on automatically when the hatch is opened and turn off when the hatch closes like a refrigerator. The lights activate via two impact switches, but I also have a main cut off switch so I can kill the power if the hatch will be open for a long period of time saving battery power.
I only have two small parts left to fabricate to finish off the deck. I can then move to the turret. More info to follow
