And we're back... Spent a fair bit of time working with the upper and lower hull to get them to fit correctly. Lots of filing, sanding, cutting, etc. but it seems to be dry fitting nicely at this point.
Onto some pictures.
Here's the finished front end. The fender detail is now correct, and the detail at the front bottom of the glacis plate has been removed, as I've got a replacement from Formations that fits the lower hull. It's primed because I had to fill and sand, and wanted to see how it looked before painting. Unfortunately, as you can see, the front end isn't all that open, so a lot of the detail of the driver's compartment will be hidden.
![](../../../img821.imageshack.us/img821/7569/img8285u.jpg)
Here's a first try at adding some weld beads. Not great, but I'll take it. I'll sand it down some since it projects out pretty severely. Also you can see the grab handles formed with wire on the engine covers.
![](../../../img204.imageshack.us/img204/1069/img8286c.jpg)
Here's the start of the lower interior. The Verlinden and Eduard conflict with placements of some stuff, so I'm basically just picking out what I want to use. Probably not the most accurate thing in the world, but it should definitely look the part in the end. You can also see that I had to cut away the flanges at the edges to fit the trans into the hull.
![](../../../img829.imageshack.us/img829/6486/img8284h.jpg)
I've cleaned up a fair bit of the lower interior pieces, but haven't installed them yet since I'll need to do some detail painting first. But for fun, I dryfitted some of the pieces to get a feel what it's going to look like.
![](../../../img441.imageshack.us/img441/3406/img8287b.jpg)
![](../../../img840.imageshack.us/img840/697/img8288g.jpg)
I'm planning on using Terry's build (http://www.perthmilitarymodelling.com/models/vehicles/m8hmc/tam35110.html) as a painting guide for my build, unless anyone sees any big flaws in what he's done. I know on the open topped tank destoryers and such, that any surface visible from above was painted OD. Terry differs slightly from this by having some of the lower hull interior still painted white, where at least at some angles, the white would still be visible.
Everything's going together fairly nicely. One problem that I have found is that the taillights are missing from the bags of parts I got. I may have to just build a tarp to hang over the rear to cover the missing pieces. the headlights and siren(?) are also missing, however, I have some spare headlights and siren from a previous Sherman build that should work well enough. Also looking through my spares box, I'll be using some dragon pioneer tools.
I'm having fun and picking up some good modeling experience along the way on this project, but I'm gonna have to do something simple after this build.
![](../../modules/SquawkBox/images/smilies/smile.gif)
