Anyone else tried Vallejo Model Air?
Bribo
Louisiana, United States
KitMaker: 205 posts
Armorama: 129 posts
Posted: Monday, August 18, 2003 - 02:45 PM UTC
I tried a couple different colors of this paint, and I have to say I was rather disappointed. The paint doesnt't seem to stick very well, and doesnt cover well either. I tried two different models, one bare, clean plastic and one primed with white enamel primer that had dried for a couple days. I used my badger 275 and my aztek 4709, didn't have much luck with either. Just curious what others experiences were.
mikeli125
KitMaker: 2,595 posts
Armorama: 1,209 posts
Posted: Monday, August 18, 2003 - 06:55 PM UTC
I've heard that they are very good and I can say that the normal paint they do sprays very well
with no problems thenagain I have no luck with life colour I've got good results with it once
and thats it
chipotle
KitMaker: 72 posts
Posted: Tuesday, August 19, 2003 - 06:02 PM UTC
Just curious mikeli125 what do you use to thin them with for spraying. I have just got some of the model color ones for hand brushing and find them excellent compared to the Tamiya paint i had been using. I was thinking of trying them in my airbrush to see how they compared. Any tips would be appreciated.
mikeli125
Posted: Wednesday, August 20, 2003 - 01:22 AM UTC
chip,
it was a while ago but try distilled water or tamiya thinner sorry but it was 2 years ago and I was still trying to figure out how to use the airbrush and I've still got the figure by dragon to show you if you like
chipotle
KitMaker: 72 posts
Posted: Wednesday, August 20, 2003 - 03:05 AM UTC
Thanks i will give them a try at the weekend.
Bribo
KitMaker: 205 posts
Armorama: 129 posts
Posted: Wednesday, August 20, 2003 - 03:20 PM UTC
Let me get this straight, so you _can_ spray the regular ones? I've seen several posts saying they were unsuitable in the airbrush, but I wondered, 'cause I've seen a few articles by MIG, where he says he uses them for airbrushing, but never how.
mikeli125
Posted: Thursday, August 21, 2003 - 10:38 PM UTC
yup I've sprayed them trough my aztek 4709 airbrush before no problems either and it was the normal ones as well
Bribo
KitMaker: 205 posts
Armorama: 129 posts
Posted: Tuesday, August 26, 2003 - 01:56 PM UTC
Very Cool. Did you just thin them with distilled ater, alcohol, or go with the Vallejo thinner?
mikeli125
Posted: Wednesday, August 27, 2003 - 04:21 AM UTC
bribo,
I either just used water or alcohol i cant remember which sorry
chipotle
KitMaker: 72 posts
Posted: Wednesday, August 27, 2003 - 05:12 AM UTC
Bribo i have the day off work tomorrow and intend to try airbrushing with them (didn't get time at the weekend). I will give you an update on how they turned out in the next day or so. Please note i am not an experienced user of the airbrush just learning slowly.
csch
Buenos Aires, Argentina
KitMaker: 1,941 posts
Posted: Wednesday, August 27, 2003 - 09:36 AM UTC
I used Vallejo Model Air in several ocasions and it workwed well. Normally I donīt thin it, just apply it directly as it comes in the bottle. When I need to thin it I use Vallejo Thinner.
The thinner that you use is very importatnt in this paint.
Merlin
Staff MemberSenior Editor
AEROSCALE
#017
KitMaker: 17,582 posts
Armorama: 903 posts
Posted: Wednesday, August 27, 2003 - 10:08 AM UTC
Hi everyone
I hung back on joining this thread, because I've never tried Vallejo's Model Air.
I've tried the Model Color and posted a thread to get some advice... there's plenty of helpful tips here:-)
Airbrushing Vallejo acrylics
All the best
Rowan :-)
chipotle
KitMaker: 72 posts
Posted: Thursday, August 28, 2003 - 01:20 AM UTC
Well i finally got round to trying to airbrush the Vallejo model colour paints. The results of a not too scientific test are here
http://groups.msn.com/armorama/chipotlesbits.msnw?action=ShowPhoto&PhotoID=13143
I was going to use a 1:1 ratio of each thinner but this would not work for the iso and the Vallejo thinner. Paint used was 894 Russian green shot through an Aztek 470 with the black nozzle onto a piece of plastic card. Pressure was 15-20 psi.
A= 1:1 Paint and filtered water (distilled not available) I found it sprayed ok but i did get a small amount of running due to spaying too much paint. Drying time was longer than with the other two thinners. Once dry the coverage was good and even.
B= Paint + isopropanol. I mixed it 1:1 to start but i found it was too thick so i added more iso till it was ok to spray. I thought the results were better than A with faster drying time and more even coverage. It is worth mentioning that when added together it looked like the liquids congealed but after a good stirring the mix was OK.
C= Paint + Vallejo thinner 061.Once again i had to add more thinner than paint to get the correct mixture. This went on well about the same as the iso mix. When you add the thinner it is a milky colour but that does not appear to affect the final sprayed appearance and dissapeared once stirred.
In conclusion i will be using either the iso or vallejo thinner. I am sure if i played around with the water mix a bit more i could get better results for spraying. I normally use Tamiya for airbrushing and find them very good. The reason i initially got the vallejo paints was for dry brushing as the tamiya dries too fast.
I hope this helps you out Bribo, as i said i am not the best when it comes to airbrushing so take these results as a very rough guide.
