TRACKS
Originally I wanted to use the excellent detailed Bronco workable link tracks and started cutting and cleaning hundreds of individual parts. But somehow some crazy problems were evident. After finishing one section suddenly the trackpads fell apart! The pins (red arrows) were used as bonding points for the pads. On my track they werde clearly too short! The glue can not connect. Glueing the trackpads edges is not possible because otherwise the capillary action will glue the movable parts and the chain will not be longer movable. I should have fill up the pins height sheet so that a bond can develop.
No thanks - this is to me too much effort for the tracks. So I take the kits vinyl tracks which are really not bad. (BTW I have neither - at an exhibition or on the Web - ever seen pictures of a model with Leclerc Bronco chains mounted - did the other modellers also face similar problems?)
Here are the kits vinyl tracks. Primed with Tamyia Surfacer, then painted with black matte. End parts were painted silver and then with Tamiya Hull Red "made rusty". Finally the tracks were weathered with reddish and brownish pigments from different manufacturers. The pigments were fixed with white spirit.
Even the roadwheels were handled in accordance with pigments ... and you see already, there will be a little dirt ;-)
The tracks are mounted on the model. The vinyltracks were glued with thamiya cement which works surprisingly fine.
Footprints? Yep, these funny footprint-stamps are made by Calibre. Just dip it into some paint, dab and start tramping. There's even left and right footprint available ... it was fun to walk around.
Here, the footprints of the crew. My model will become pretty dirty, did I already mention it ;-)
FIGURE
Although I am not a great figure painter, I just like when characters animate the model. It just looks more authentic and credible and I like the nice size comparison.
Here's the commander - a French tank crew man resin made from BLAST MODEL. the figure was painted with various colors of acrylic Vallejo and Andrea range.
On the photo you can also tiny little decals - french flags made by myself and un-badges made by Echelon Decals. This UN badges from Echelon is created by the presentation of one of my badges from my UN mission in Lebanon, which I had provided to them. They contacted me in my build-blog for my UN Leopard 1A5DK a while ago.
http://p47.kitmaker.net/forums/140219#1172127Now "my" decals are used for the first time, previously I had always painted the flags manually, but now my hands tremble too much so the decals become a really great help.
By the way, did I mention that my tank will become pretty dirty ;-)
The model is straight in the middle of the weathering process (mainly oil paints and experiments with different pigments). The final details such as machinegun, flag, additional lights to flag, antennas, etc. must be completed and the final assembly is to do.
The next update will be done with pictures from the finished model.
Stay tuned
cheers
Walter
