I could have sworn someone had made proper T-55 sprockets for the T-72 RmSH track upgrade, but searches turn up dated material. Anyone recall such a thing?
TIA,
Jim
Яusso-Soviэt Forum
T-55 RmSH sprockets?
junglejim
KitMaker: 1,728 posts
Armorama: 1,629 posts
Posted: Tuesday, April 26, 2011 - 11:33 AM UTC
Jacques
KitMaker: 4,630 posts
Armorama: 4,498 posts
Posted: Wednesday, April 27, 2011 - 04:10 AM UTC
Well, SP Designs has made the new sprockets and puts them in the T-55 based kits, but there is no seperate sprocket set.
http://saammodels.tripod.com/companies/spdesigns/T55/sp177/index.htm
rolf
KitMaker: 301 posts
Armorama: 250 posts
Posted: Wednesday, April 27, 2011 - 04:25 AM UTC
TIA,
Jim
There are a few things you can do, Trumpeter's T-62 Mod 72 gives you both type of sprockets but only the RMSh tracks. If you sorced a set of OMSh tracks for it you could rob the sprockets from that kit. Also Skif's T-55 kits come with the proper sprocket for the RMSh tracks and that is about the only usable thing in that kit. Also I believe Airdale Casting made a sprocket but I am not sure if it was a seperate item or part of a larger conversion like the SP Design's kits. Lastly you can try and scratch a set using Tamiya T-72 and T-55 sprockets. Alot of work but doable. Givin the low price and availability of the Skif kits that might be the easiest way to go.
Roy
Roy
junglejim
Posted: Wednesday, April 27, 2011 - 09:06 AM UTC
Thanks, I have a Mod 72 T-62 on the way, I'll see what they look like. The scratchbuild is another option, I was worried about ruining a set of Tamiya T-72 sprockets but I have replacements in the Friul set.
Jim
Jim
zapper
KitMaker: 745 posts
Armorama: 734 posts
Posted: Wednesday, April 27, 2011 - 11:00 AM UTC
Howdy Jim,
Got two sets of the Airedale castings/Andy Taylor offerings at Telford last year. Looks really nice. If you need a set you could probably just drop them a line:
http://www.airedalecastings.pwp.blueyonder.co.uk/index.html
/E
/E
TonyDz
KitMaker: 420 posts
Armorama: 419 posts
Posted: Wednesday, April 27, 2011 - 04:56 PM UTC
WWII Productions made a set he would sell seperate, but I think he may have gone under. The sprockets in the Trumpeter T62 Model 72 are very nice and you also get the sprockets for the Omsh track too. Fruils will drop right on to the Trumpeter sprocket no problem.
guni-kid
KitMaker: 521 posts
Armorama: 514 posts
Posted: Wednesday, April 27, 2011 - 08:59 PM UTC
Isn't FRIUL coming with proper sprockets in their T-72-Track Set? I recall it as one of the few sets with sprockets added, the question is: are they good stuff?
stephane
KitMaker: 432 posts
Armorama: 429 posts
Posted: Thursday, April 28, 2011 - 02:08 AM UTC
T55 sprocket for T72 style tracks isn't the same as T72 sprocket.
The two sprocket have just in common the "teeth" ring.
TonyDz
KitMaker: 420 posts
Armorama: 419 posts
Posted: Thursday, April 28, 2011 - 06:16 AM UTC
The sprockets are good for a T72. As pointed out they are not the correct ones for a T55/62.
junglejim
Posted: Thursday, April 28, 2011 - 03:19 PM UTC
Yep, this is what I need for my T55 Marksman:
It's not quite the same as a plain T-72 sprocket.
The Friul T-72 sprockets provided with their tracks still need the kit retainer ring and poly cap. The Friul tracks themselves are good. I just discovered the WW 2 T-72 tracks in my T-72 kit; I'll have to see if the Trumpeter T-62 sprocket will fit them too.
BTW, for anyone thinking they can plop the newish Accurate Armour Marksman turret on the T-55 hull and call 'er done are in for some work! I'll get a blog started as soon as I get the rest of my reference material
Jim
Jim
guni-kid
KitMaker: 521 posts
Armorama: 514 posts
Posted: Thursday, April 28, 2011 - 09:21 PM UTC
Alright, you got it!
Guess I have to take another close look next time I'm heading for an RmSH equipped T-Tank
SEDimmick
KitMaker: 1,745 posts
Armorama: 1,483 posts
Posted: Friday, April 29, 2011 - 02:31 AM UTC
I got a couple copies of the Airedale casting Sprockets and they are very nice!
pseudorealityx
KitMaker: 2,191 posts
Armorama: 1,814 posts
Posted: Tuesday, June 07, 2011 - 05:57 AM UTC
WWII Productions is still around, but does not make a set that he will sell separate. He suggests using the Miniarm version available at Hobby Easy.
http://www.hobbyeasy.com/en/data/lb1sk7teu6aexyegrroh.html
