I actually started my build on the 5th of this month so that I am fairly well along. It is my intention to submit this build as a build review so it is well documented with images.
Here's some requisite starting pictures prior to beginning construction.
While the kit lists 102 part numbers, some parts have as many as six similar pieces on the sprue. I estimate the total parts at around 170 or so. The first part of the instructions was to build the two sets of the water propulsion system. The penny in the picture should give an idea of the size we are dealing with.
I completed these pieces the first day and attached them to the lower hull.
After having built the Revell Luchs I mistakenly anticipated that this suspension would be a breeze as it had only six axles as opposed to the eight on the Luchs. I was about to experience a shock but first I felt that a minor embellishment to the build would be worth while. As there is a clear windshield one can see into the interior. After looking into it with the hull pieces dry fitted together this proved correct. Therefore, I decided to scratch together at least a rudimentary interior from plastic sheet and odds and ends.
While parts of the interior were drying I started to assemble the rear most axle. It was at this point that I saw that this suspension would be even worse than the Luchs with all the separate tiny pieces. Most of it must be assembled off the vehicle and then you have to get a half dozen pieces to line up in different locations at almost the same time.
I was in for a greater shock when I started to assemble the front axles. Revell gives you the option of assembling them with the wheels in a turned position so the ends of the axles must remain moveable until final assembly onto their mounting arms.
As an example of the complexity of this middle axle, the axle itself is made up of 12 parts, the steering linkage is another 7 and there are four support arms (springs and shock absorbers).
The entire process to this point has taken the free time over almost two weeks.
Jan
