What does that mean? It means I forgot the waterline on this small scene. It'll be dark, dirty canal water and you won't see much below a certain point. Baring this in mind I had to get the 'sit' of the figure correct. I thought I had it sorted...but no, modeller's law right?
So I ended up figuring out exactly where the water-line would be- right on the waist-belt of the figure. Then I also had to factor in the cable that will 'hold' him in the scene- it will be wrapped around his neck, chest and right arm- pinning it to his side and I had to make this look right while trying not to have the arm step outside the very tight confines of the base. This meant a massive sanding and re-sculpting job.
As you can see I've sanded away most of my work beneath the waist which was rather annoying considering the time I'd taken to sculpt it. His chest, right arm and neck have been sanded down with a round file and chisel to accomodate the cable. His left arm looks quite big right now compared to the right because it is still curing prior to being sanded down a bit.
I am really chomping at the bit now to get the paint started on this figure!
Last week I got some very useful constructive criticism from a friend. The most obvious result of this on the base is the bullet marks on the masonry.
The bullet strikes are not yet finished, they've just been drilled and roughened up. I have some work to do on them yet. Some of the weathering on the edge of the canal has also been removed as I plan to add moss to some parts.
I also realised some parts of the Kubelwagen's top-cover frame sat proud of the base edges and I sanded these back- they won't be seen under the water-line but I'll re-paint them anyway.
I'm still experimenting with various water finished but I think I've got what I need.
So hopefully I'll be starting to paint the sculpted figure soon.
Anyway, thanks for reading and taking a look.
Cheers.
-Karl187-
