Vladpanzer, I put some pictures of the product, but is basically sewing pins
Posty1978, I'll post some pictures of a "step by step" how to do it, ok.
thanks for the posts.
a big hug
Dioramas
A break to rest
rodrigo_sartori
KitMaker: 160 posts
Armorama: 159 posts
Posted: Saturday, September 24, 2011 - 09:58 AM UTC
posty1978
KitMaker: 186 posts
Armorama: 161 posts
Posted: Sunday, September 25, 2011 - 11:33 PM UTC
pdelsoglio
KitMaker: 561 posts
Armorama: 553 posts
Posted: Monday, September 26, 2011 - 03:13 AM UTC
Rodrigo,
If you are new to modelling, that is an impressive job!!!
The bridge is outstanding, and the progress in your house is superb.
Keep those pictures coming, it will be a pleasure to follow your progress.
Pablo
Pablo
rodrigo_sartori
KitMaker: 160 posts
Armorama: 159 posts
Posted: Monday, September 26, 2011 - 04:57 AM UTC
Pablo, thanks for your comment. as I said earlier, I have some experience in assembling models of buildings, but is very different. It has to be everything clean...
Rodrigo
Rodrigo
rodrigo_sartori
KitMaker: 160 posts
Armorama: 159 posts
Posted: Monday, September 26, 2011 - 05:31 AM UTC
Well, to explain what type of wood I use, as I cut and I use to "simulate" the nails and screws used in the bridge, see the photos below.
I use a piece of wood about 1mm.
It's very simple. I use a cutter and a ruler. Since wood is very thin, it's very easy to cut
TIP: The wood strips are much stronger if cut direction in the fiber of the wood
You can also use a guide, trapping the wood with tape and cutting along the strip of wood.
this is the stuff that I use to simulate the screws / nails the bridge
They are very long, so I literally cut and use as nails, hammering ....: D: D: D
rodrigo_sartori
KitMaker: 160 posts
Armorama: 159 posts
Posted: Monday, September 26, 2011 - 05:44 AM UTC
More photos.
retiredyank
KitMaker: 11,610 posts
Armorama: 7,843 posts
Posted: Monday, September 26, 2011 - 06:32 AM UTC
Rodrigo, you may think your attempt amateurish, but I'd buy a scale house from you any day of the weeks. Your results are superb. From the few houses I have helped build, you seem to be using the same methods carpenters use. Keep on building and never let failure or ignorance get you down. I'm learning new things from your build. Good luck on fixing the demag.
rodrigo_sartori
KitMaker: 160 posts
Armorama: 159 posts
Posted: Monday, September 26, 2011 - 08:23 AM UTC
thanks, Matt.
Is a pleasure to share with you. My Demag is already assembled and painted. Particularly did not like the wear and washing it. I have photos of the process of assembly and painting. I'll post pictures soon.
How my dog destry it, I'll try to perfect now and it's likely I'll have to make some plays, because they have lost.
But that's it. We can not discourage
rodrigo_sartori
KitMaker: 160 posts
Armorama: 159 posts
Posted: Monday, September 26, 2011 - 02:48 PM UTC
more photos:
Woodshed
I have used matchsticks to make the structure of the woodshed and the same strips of wood used to make the house.
Woodshed
rodrigo_sartori
KitMaker: 160 posts
Armorama: 159 posts
Posted: Monday, September 26, 2011 - 03:29 PM UTC
My dogs
rodrigo_sartori
KitMaker: 160 posts
Armorama: 159 posts
Posted: Monday, September 26, 2011 - 03:39 PM UTC
Plaster applied over the base to simulate stones
while the plaster dries .....
rodrigo_sartori
KitMaker: 160 posts
Armorama: 159 posts
Posted: Monday, September 26, 2011 - 03:44 PM UTC
painting the chimney.
rodrigo_sartori
KitMaker: 160 posts
Armorama: 159 posts
Posted: Monday, September 26, 2011 - 03:57 PM UTC
rodrigo_sartori
KitMaker: 160 posts
Armorama: 159 posts
Posted: Tuesday, September 27, 2011 - 04:30 AM UTC
advancements in the base
rodrigo_sartori
KitMaker: 160 posts
Armorama: 159 posts
Posted: Thursday, September 29, 2011 - 04:06 PM UTC
Hi,
More advancements in the base.
On the riverbank, I usually apply a technique I use here in Brazil.
I seek tree barks that contain mud and put it in a closed box (so that no illumination). I leave it stored for a long time (3-4 months), it will dry naturally and it will remain the natural color. However I like to apply a little paint, because from this moment it will be exposed to light again and may lose a bit of color.
what you see below is purely natural colors of the mud "dehydrated"
rodrigo_sartori
KitMaker: 160 posts
Armorama: 159 posts
Posted: Thursday, September 29, 2011 - 04:22 PM UTC
I started the figures
And here, my demag, before they crash .....
There is not cool .... I want to enjoy it. This Demag is mounted for about 4 years. I dont want to lose it
But I'm renovating it. Not broken much.
Particularly did not like this painting and "wash" I think it was very dark
I dont like it that way, but to remove the paint and repainting will take a lot more work
rodrigo_sartori
KitMaker: 160 posts
Armorama: 159 posts
Posted: Thursday, September 29, 2011 - 04:34 PM UTC
next step is to apply water based (polyester resin crystal).
Now it's like I rode my tree.
I used thin wire (a lot of them). All positioned side by side and was turning and shaping twigs.
VLADPANZER
KitMaker: 568 posts
Armorama: 549 posts
Posted: Thursday, September 29, 2011 - 11:00 PM UTC
Hey,
Great progress Rodrigo!!! It’s really starting to take shape, I really like the half-track!! And those are some nice dogs!
rodrigo_sartori
KitMaker: 160 posts
Armorama: 159 posts
Posted: Thursday, September 29, 2011 - 11:59 PM UTC
Vlad, now it starts to take more share.
I will apply the resin base. I already have a PAK 38 (I'll put in the trailer) and I also use a shwinwagen.
regards,
regards,
tommy1drop
KitMaker: 131 posts
Armorama: 116 posts
Posted: Friday, September 30, 2011 - 12:14 AM UTC
Hi Rodrigo
Excellent work, the more you see the more you want to see!
Simply fantastic and inspiring, looking forward to seeing more of this Dio.
Tom
Tom
MDDMack
KitMaker: 11 posts
Armorama: 10 posts
Posted: Friday, September 30, 2011 - 06:57 AM UTC
Very, very nice. Your woodworking skills are amazing.
pdelsoglio
KitMaker: 561 posts
Armorama: 553 posts
Posted: Friday, September 30, 2011 - 07:28 AM UTC
Hi there Rodrigo!
Nice prgress, man! Congratulations. The roof is quite convincing.
I have a little question: What did you use to weather the wood of the Bridge?
Thanks for sharing.
Pablo
Thanks for sharing.
Pablo
rodrigo_sartori
KitMaker: 160 posts
Armorama: 159 posts
Posted: Sunday, October 02, 2011 - 07:41 AM UTC
Pablo
well, to age the wood of the bridge I use a stain for varnish. Very common to find them homes of paint. These stains have a very strong pigmentation, then I diluted with thinner.
I do not mix the stain in the varnish, because the varnish takes too long to dry and also I would have to buy a gallon of matte varnish. This would be an eternity here.
So I use the stain pure, diluted with thinner.
There are various shades of color (depends on type of wood)
this is the look below. They are two different colors
rodrigo_sartori
KitMaker: 160 posts
Armorama: 159 posts
Posted: Sunday, October 02, 2011 - 08:06 AM UTC
A cerca na beirada da estrada também foi feita com a mesma folha de madeira e envelhecida com o tingidor.
a big hug
a big hug
pdelsoglio
KitMaker: 561 posts
Armorama: 553 posts
Posted: Sunday, October 02, 2011 - 08:31 AM UTC
Rodrigo,
Nice job on the fence.
Pablo
Pablo
