Hi folks,
Firstl;y, Ken thanks for the data on the boxes and shells.
The Bronco Ammo set gives you 4 boxes of the following types.
C247 Mk I (Wood) - these are the ones that I have marked with the yellow band. As Ken points out the Yellow Band denotes Practice Rounds but if you leave it off this type contained 2 rds of HE, AP or APC.
C288 Mk I (Steel) These are the smaller of the two and contained 2rds of APDS, APC, AP or HE
C317 Mk I (Steel) These are the larger of the two steel boxes and contained 2rds APCBC
C310 Mk I (Wood) These are the wooden boxes with the Rib on the top and contained 2 rds of APCBC
The wooden boxes are of simple construction and can be modelled open or close empty or with the rds in. You get plastic rope handles to add to the boxes and these can be positioned to suit your needs so you could have a figure(s) carrying them or dragging them which is a nice touch.
The steel boxes are a little more fiddly and require a small PE insert in the open end. then you fit 4 very small parts for the end if in the closed position. You get two options one to show the boxes open and empty or with rds half in/out and one to show the boxes closed. Choose the appropriate PE for the box from the small frets provided. The finishing parts for the closed steel boxes are very smal so be careful of the carpet monster. Hiowever, if you leave one or two open then you will have additional fittings in case of emergency!!
With the decals for both the rds and boxes this is a terrific set of ammunition boxes, really cracking.
If you're leaving any of the steel boxes empty it might be a good idea to paint the inside first!!!
if you don't need so much ammo then the 17pdr gun comes with a single tree of the boxes and ammo that will give you two of each type of box and shell
Al
