Hi All,
As with all stories, this one now draws to a close. When i last left you, the model had gotten its overall wash and dot filters. It was now time to add the final touches. First, I located a set of the stick-on clean "buttons" used in scrapbooking instead of the costly MV lenses for the headlight lenses. The product is made by Sticko (I think this is appropriate) and is part number 52-20049 and are called
"shimmering silver dots." For about US$5 you get 90 of them in various sizes. A great deal, I think!
The final step was to apply weathering powders and make some mud. I used a couple of colors from MMP, who are now, unfortunately, defunct. I used their "medium earth" and "concrete dust" mixed up with some white PVA glue, water and a drop of rubbing alcohol (to break the surface tension to aid in mixing). First and thick"glop" of the stuff was applied to the lower hull sides, running gear and track to show, dried, packed earth. This was allowed to dry and then dry powder was piled in various places and thinner added to fix them in place. Finally, a thin mix of a lightened version was mixed up with alot of windex and airbrushed overall to blend everything together. Once this had dried, I added a little more dark brown to the mix and then dipped a large round brush into the mix. Using my airbrush at about 40 psi, I blasted the contents of the brush onto the lower hull and sides to show dirt/mud splatter.
The final bit of weathering was to show leaking or overfilled bearings. For this I used an AK Interactive product I picked up at the last
IPMS/AMPS East show. It's part of the "Engines and Metal Weathering set" and includes a "Fresh Engine Oil wash which is perfect for seeping oil or grease.
Well enough prattle, here are the pics!
I plan on doing a small vignette with this later, using some really disturbing figures in WW1 uniforms wearing gas masks and carrying modern-looking weapons. But for now, the vehicle is done and I'm getting ready to move on to the next one. Any and all comments are welcome.
Georg
