I'd have to go rutting through my aftermarket stash, but I remember dolling out $16 bucks for a set of HEMTT replacement tires. Considering expense, though, I might reconsider using them. If you take Chris' approach (and animal's displayed result) extending the armor plating further down negates the need to chuck the ugly Italeri wheels. The Italeri kit is expensive enough already.
Gunnie
Good points Gunnie! Heck tho', only $16. for a set of AM resin HEMTT wheels?? Not bad, but as you say (and I plan), if I'm hiding the Italeri wheels behind armour plating that takes care of that! Yeah, I know,
that's the idea I'm stealing from 'animal'
Or at least part of his idea. There will be armoured skirts on all the rear wheel arches, but I have designed something rather unique for the front set of tyre's.
Speaking of idea's......I was planning on saving this as a bit of a surprise, but I've decided to breach the idea now instead so that I can possibly get some input.
I'm talking about my 'rear' HEMTT. My plan is to create a kind of non-nuclear 'first-strike' towed platform that can be either towed into position and left in-place for a period of time, or, towed to a position just outside an occupied city and begin bombardment for a fixed time, then quickly folded up and moved to a new position (to avoid the possibility of the enemy 'zeroing in' ).
Anyway, originally I intended to mount
two of the new Trumpeter SA-2 Missles on the truck. But that would only facilitate a maximum of two launchings. I wanted something with a little more Ummphh!, and a little more 'staying' power. And since there has been some talk of tactical nuclear exchange's,
and since there has really been NONE of this type of thing presented yet, I have reconsidered and switched to heavy artillery!! And when I say heavy, I mean heavy.
I needed something that would have some real
punch, but would also concievably fit on the platform I'm building and be able to function with some believability. Guns like the 'Long Tom' were out, even the long barreled M-107's. So, what I came up with (and this is were you guys can step all over my idea
) is, a set of
two 230MM artillery pieces mounted on (let's just say an enlarged and beefed up) the rear 10-Ton HEMTT truck. That's right, I said
230 MM!!I'm taking them from the Revell of Germany 'Haubitze' SPG kits. I have spent a significant amount of mental time on the math, engineering, architecture, etc. to make the configuration work I believe. BUT, I would like you guys to shoot it down so I can figure out 'go-arounds'
Tell me what you think.
Thx,
Tread.
