Greetings from Tanzania again,
Here’s what I’ve done.
1 Anti Slip coating (done panel by panel)
a. Model primed to assist in white glue bonding
b. White glue heavily diluted with water n brushed onto surfaces.
c. Fine beach sand sprinkled on surface held vertically.
d. If sand does not bond evenly, leave it alone until white glue dry first n then touch up. If not, it will be disastrous. But can be washed off before white glue dry.
e. Prime the anti slip surface again n the paint will bond it permanently.
However, I did not border to use any masking for the above which I am sure will enhance the anti slip.
2 The TC is from Dragon’s IDF tank crew with his head sourced from Dragon’s modern US tank crew. Crew cut done by dabbing bald head with Mr Hobby surfacer.
3 Academy method of constructing the balls n chains is crazy. Instead, I trim the flat round end into thin strips to super glue them into the holes of the key chain metal balls.
4 Here's the in progress painting steps. The pics' colour seems to be affected by the lighting conditions n the white balance setting of my camera.
Lee
