Maus 1:35 with interior
jmsbd07
KitMaker: 96 posts
Armorama: 94 posts
Posted: Friday, November 06, 2015 - 10:26 AM UTC
Great to see more progress on this. I am interested to see what modifications of the engine will be added, and the generator attached to it.
FlorinM
KitMaker: 385 posts
Armorama: 211 posts
Posted: Saturday, November 07, 2015 - 10:55 AM UTC
The generator is made of three electric motors, two of which are identical, and a smaller one, about half their size. Not only that, but the larger, identical motors are the same with the ones that move the vehicle. Will need four identical parts, so just one will be made and then cast in resin three more times. Next is the shorter section, the air intake at the front and finally the heat exhaust at the other end. Sounds easy enough, so better get to work, you guys want to see results!
Thirian24
KitMaker: 2,493 posts
Armorama: 2,344 posts
Posted: Saturday, November 07, 2015 - 11:51 AM UTC
Thanks for providing some history along with this! I'm very intrigued. Nice work!
Mecsweden
KitMaker: 137 posts
Armorama: 136 posts
Posted: Tuesday, March 08, 2016 - 02:48 PM UTC
Absolutley an amazing build , waiting for updates
Cheers Magnus
Cheers Magnus
FlorinM
KitMaker: 385 posts
Armorama: 211 posts
Posted: Tuesday, March 08, 2016 - 08:42 PM UTC
Not just yet, real life won't let me... Things will settle down eventually and will hopefully resume work in May-June.
Mecsweden
KitMaker: 137 posts
Armorama: 136 posts
Posted: Tuesday, March 08, 2016 - 11:12 PM UTC
Hope everything turns out well , looking forward to the may/june update
Cheers magnus
Cheers magnus
maartenboersma
KitMaker: 764 posts
Armorama: 742 posts
Posted: Monday, May 09, 2016 - 03:34 AM UTC
We are well into May
.....any updates from this Great build yet?
FlorinM
KitMaker: 385 posts
Armorama: 211 posts
Posted: Monday, May 09, 2016 - 10:57 AM UTC
Thank you so much for the continuing interest! I was commissioned to do a couple of 1/32nd Japanese aircraft, a Ki-61 and a Ki-84, an interesting project, covering them with aluminum foil that will be weathered. Needless to say, this has pushed back my modelling schedule but I desperately, desperately need the money. After that is finished, work must and will resume on the Maus, for it started too long ago and needs to be finished.
HistoricArmor_97
KitMaker: 16 posts
Armorama: 16 posts
Posted: Thursday, September 08, 2016 - 05:52 AM UTC
I just want to say that skill to this level is rarely exhibited. You have taken great care with great respect during this entire build, and no matter how long it takes you, I'll be here to see it finished. Hats off to you mate. Cheers!
plstktnkr2
KitMaker: 352 posts
Armorama: 309 posts
Posted: Thursday, September 08, 2016 - 09:08 AM UTC
I am here for the long haul as well. I have not completed a model in a long time. You are an inspiration
SSGToms
KitMaker: 3,608 posts
Armorama: 3,092 posts
Posted: Thursday, September 08, 2016 - 09:23 AM UTC
Florin, I continue with my 2 or 3 month projects, but I've been following your Maus build with great interest! Move along and keep up the excellent work!
FlorinM
KitMaker: 385 posts
Armorama: 211 posts
Posted: Thursday, September 08, 2016 - 11:21 AM UTC
A big thank you, Guys for the pat on the back, I really,really needed the nudge to resume work on this project. The amount of work ahead is staggering, but I would very much like to see this complete, finally done! There are a couple of things that need wrapping up, real life conspires to keep me off the work bench... But hopefully my next post will show you the engine exhaust, and then the radiators with their fans, the engine completed, and so on and so on.
jrutman
KitMaker: 7,941 posts
Armorama: 7,934 posts
Posted: Thursday, September 08, 2016 - 06:43 PM UTC
Yeah man,
Knock the lazy monkey off of your back and get back to this!! Ist Befehl !!!
J
J
FlorinM
KitMaker: 385 posts
Armorama: 211 posts
Posted: Sunday, September 11, 2016 - 09:52 AM UTC
When Mr. Rutman gives an order, then I'd better deliver!
These rough shapes represent the intermediary mufflers. Need to search for tubes or sprues of the right diameter to complete the exhaust system.
pimpdogbert
KitMaker: 131 posts
Armorama: 88 posts
Posted: Sunday, September 11, 2016 - 10:14 AM UTC
Woo! It's time for a celebration! Been hoping for a update for some time now. Great work Florin keep up the amazing work!
jrutman
Posted: Sunday, September 11, 2016 - 06:40 PM UTC
That's right soldier. And you better be standing at the position of attention while you build !!
J
J
FlorinM
KitMaker: 385 posts
Armorama: 211 posts
Posted: Sunday, September 11, 2016 - 09:03 PM UTC
SIR, YES SIR!
FlorinM
KitMaker: 385 posts
Armorama: 211 posts
Posted: Sunday, September 11, 2016 - 09:07 PM UTC
The next stage requires finding or making two cylinders 7.7 millimeters exterior diameter and 31 mm in length. Hope this won't take too long...
HistoricArmor_97
KitMaker: 16 posts
Armorama: 16 posts
Posted: Sunday, September 11, 2016 - 11:29 PM UTC
Well I work with wiring and stuff all the time and there is some 7.7mm heat shrink tubing I use. It seems to be somewhat thick though. Just an idea.
FlorinM
KitMaker: 385 posts
Armorama: 211 posts
Posted: Monday, September 12, 2016 - 12:10 AM UTC
Said cylinders will become the final mufflers. After ransacking my place, all I've managed to find is a wax crayon, green in color. To avoid joining and painting complications will make the things out of rolled white styrene.
FlorinM
KitMaker: 385 posts
Armorama: 211 posts
Posted: Tuesday, September 13, 2016 - 04:53 PM UTC
Problem solved! The center sections, 8 mm in diameter and 1.6 cm long, from four U.S. bombs in 1/32nd are about to become two final mufflers for the Maus:
Posted: Tuesday, September 13, 2016 - 05:45 PM UTC
@FlorinM - Florin,
It's good to see you back with this project. You're off to a bombing start!
~ Eddy
~ Eddy
jrutman
Posted: Tuesday, September 13, 2016 - 06:50 PM UTC
Simple solutions are always the best.
J
J
plstktnkr2
KitMaker: 352 posts
Armorama: 309 posts
Posted: Tuesday, September 13, 2016 - 07:05 PM UTC
Great work ! Glad to have you back at it! I live for your updates, YOU ROCK
Templario
KitMaker: 42 posts
Armorama: 37 posts
Posted: Tuesday, September 13, 2016 - 08:54 PM UTC
Beautifull work I like it.
regards
regards
